multylayer switching
as12john_A
Frequent Visitor
Frequent Visitor
Hi all.My problem:
 I cannot  ping  this 192.168.10.9 from 192.168.40.2  and vice versa.
7 Replies 7
sujsingh1
Visitor
Can you explain it with some more details, like what is the topology you are using.
as12john_A
Frequent Visitor
Frequent Visitor
VTP :VLAN TRUNKING PROTOCOL
In order to look into your issue, we need logical/physical topology and configuration.
Thanks for taking the time.However, I think, I have sent all that should be.
is it in problem.pkt file ?, not able to open this file in my PC, I will check after installing packet-tracer and get back to you.
It is created by packet version 7.1.0
Thanks all. I have finally solved it.
