MX LAG
P4ck3ts
Community Member
hello,
Can I configure LAG on an MX into an SG switch? or does it only work on MS?
thanks
GreenMan
Link aggregation / LACP / 802.3ad is not supported on the MX. You can still set up dual uplinks to your MX but plan on using the fact that MXs forward STP BPDUs, to enable the switch network to block / unblock links as needed to resolve loops and restore connectivity in the event of a failure.
5 Replies 5
aleabrahao
Meraki Community All-Star
MX doesn't support LAG.
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Layer_2_Functionality#LACP_.26_Link_Aggregation
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
thank you. i was looking at the wrong doc.
GreenMan
P4ck3ts
Community Member
thanks!
ChristophJ
Community Member
LACP isn't supported on the MX. But there are topologies that Meraki recommends with Spanning-Tree:
You can find them in their documentation:
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair#:~:text=USB%20cellular%20dongle.-,Recommended%20Topologies,-There%20are%20two
