My Cisco867AE won't to talk to my ASA5510.
jvujcich
Should be a simple act, but no matter what I do, I can't ping from my ASA5510 to VLAN1 of the Router.
ASA5510 Interface:
interface Ethernet0/0
speed 100
duplex full
nameif Outside-Internet
security-level 0
ip address 122.56.33.108 255.255.255.248
Router Interface.
interface FastEthernet0
Description ToASA5510(eth0/0)
no ip address ! Because you can't put ip address on L2 interface
interface Vlan1
Description IPforFast0
 ip address 122.56.33.110 255.255.255.248
Router#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  administratively down down
Ethernet0                  unassigned      YES NVRAM  administratively down down
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  down                  down
GigabitEthernet0           unassigned      YES unset  down                  down
GigabitEthernet1           122.56.100.113  YES NVRAM  down                  down
Vlan1                      122.56.33.110   YES NVRAM  up                    up
sh ip route
ip route 0.0.0.0 0.0.0.0 122.56.100.112
122.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        122.56.33.104/29 is directly connected, Vlan1
L        122.56.33.110/32 is directly connected, Vlan1
All ASA polices have been set to any/any/any
ciscoasa# ping 122.56.33.110  --- fails
What's missing?
try and add:
icmp permit any Outside-Internet
are you allowing ICMP on the outside interface ? Post the full config of your ASA...
Sure, Here it is:
(You'll notice the E0/0 interface is down, Thats only because i have the router disconnected while i look at another issue).
: Saved
: Serial Number: JMX1049K21L
: Hardware:   ASA5510-K8, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
ASA Version 9.0(4)42
hostname ciscoasa
enable password xxxxxxxxxxxxxxx encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
passwd xxxxxxxxxxxxxxxxxx  encrypted
names
 speed 100
 duplex full
 security-level 100
interface Ethernet0/1
 no nameif
 security-level 100
 no ip address
interface Ethernet0/1.50
 vlan 50
 nameif Servers
 security-level 100
 ip address 192.168.50.1 255.255.255.0
interface Ethernet0/1.202
 vlan 202
 nameif Users
 security-level 100
 ip address 192.168.202.1 255.255.255.0
interface Ethernet0/2
 no nameif
 security-level 100
 no ip address
interface Ethernet0/2.102
 vlan 102
 nameif Pod2
 security-level 100
 ip address 192.168.102.1 255.255.255.0
interface Ethernet0/2.103
 vlan 103
 nameif Pod3
 security-level 100
 ip address 192.168.103.1 255.255.255.0
interface Ethernet0/2.104
 vlan 104
 nameif Pod4
 security-level 100
 ip address 192.168.104.1 255.255.255.0
interface Ethernet0/2.105
 vlan 105
 nameif Pod14
 security-level 100
 ip address 192.168.105.1 255.255.255.0
interface Ethernet0/2.107
 vlan 107
 nameif Pod1-Jeff
 security-level 100
 ip address 192.168.107.1 255.255.255.0
interface Ethernet0/2.110
 vlan 110
 nameif Pod10
 security-level 100
 ip address 192.168.110.1 255.255.255.0
interface Ethernet0/2.115
 vlan 115
 nameif Pod15
 security-level 100
 ip address 192.168.115.1 255.255.255.0
interface Ethernet0/2.116
 vlan 116
 nameif Pod16
 security-level 100
 ip address 192.168.116.1 255.255.255.0
interface Ethernet0/2.118
 vlan 118
 nameif Pod18
 security-level 100
 ip address 192.168.118.1 255.255.255.0
interface Ethernet0/2.119
 vlan 119
 nameif Pod19
 security-level 100
 ip address 192.168.119.1 255.255.255.0
interface Ethernet0/2.120
 vlan 120
 nameif Pod20
 security-level 100
 ip address 192.168.120.1 255.255.255.0
interface Ethernet0/2.121
 vlan 121
 nameif Pod21
 security-level 100
 ip address 192.168.121.1 255.255.255.0
interface Ethernet0/2.122
 vlan 122
 nameif Pod22
 security-level 100
 ip address 192.168.122.1 255.255.255.0
interface Ethernet0/3
 no nameif
 security-level 100
 no ip address
interface Ethernet0/3.210
 vlan 210
 nameif ManageInternal
 security-level 100
 ip address 192.168.210.2 255.255.255.0
interface Management0/0
 management-only
 no nameif
 security-level 100
 no ip address
boot system disk0:/asa904-42-k8.bin
ftp mode passive
object-group icmp-type DM_INLINE_ICMP_1
 icmp-object echo
 icmp-object echo-reply
object-group protocol TCPUDP
 protocol-object udp
 protocol-object tcp
object-group service DM_INLINE_SERVICE_1
 service-object tcp-udp
 service-object ip
 service-object icmp
 service-object icmp echo
 service-object icmp echo-reply
object-group service DM_INLINE_SERVICE_2
 service-object ip
 service-object icmp
access-list ManageInternal_access_in extended permit object-group TCPUDP any4 any4
access-list ManageInternal_access_in extended permit ip any4 any4 log
access-list ManageInternal_access_in extended permit icmp any4 any4 object-group DM_INLINE_ICMP_1
access-list Servers_access_in extended permit object-group DM_INLINE_SERVICE_1 any4 any4
access-list Servers_access_in extended deny ip any any
access-list Users_access_in extended permit object-group DM_INLINE_SERVICE_2 any4 any4
access-list Users_access_in extended deny ip any4 any4
pager lines 24
logging enable
logging asdm informational
mtu Outside-Internet 1500
mtu Servers 1500
mtu Users 1500
mtu Pod2 1500
mtu Pod3 1500
mtu Pod4 1500
mtu Pod14 1500
mtu Pod1-Jeff 1500
mtu Pod10 1500
mtu Pod15 1500
mtu Pod16 1500
mtu Pod18 1500
mtu Pod19 1500
mtu Pod20 1500
mtu Pod21 1500
mtu Pod22 1500
mtu ManageInternal 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any echo Servers
icmp permit any echo-reply Servers
icmp permit any echo Users
icmp permit any echo-reply Users
icmp permit any echo ManageInternal
icmp permit any echo-reply ManageInternal
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
access-group Servers_access_in in interface Servers
access-group Users_access_in in interface Users
access-group ManageInternal_access_in in interface ManageInternal
route Outside-Internet 0.0.0.0 0.0.0.0 122.56.33.110 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 ManageInternal
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 ManageInternal
ssh timeout 60
console timeout 0
vpn-addr-assign local reuse-delay 20
no threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username admin password xxxxxxxxxxxxxxxxx encrypted privilege 15
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:0a6252208bea6c2de982747806ae0c10
: end
ciscoasa# sh int ip brief
Ethernet0/0                122.56.33.108   YES CONFIG down                  down
Ethernet0/1                unassigned      YES unset  up                    up
Ethernet0/1.50             192.168.50.1    YES CONFIG up                    up
Ethernet0/1.202            192.168.202.1   YES CONFIG up                    up
Ethernet0/2                unassigned      YES unset  up                    up
Ethernet0/2.102            192.168.102.1   YES CONFIG up                    up
Ethernet0/2.103            192.168.103.1   YES CONFIG up                    up
Ethernet0/2.104            192.168.104.1   YES CONFIG up                    up
Ethernet0/2.105            192.168.105.1   YES CONFIG up                    up
Ethernet0/2.107            192.168.107.1   YES CONFIG up                    up
Ethernet0/2.110            192.168.110.1   YES CONFIG up                    up
Ethernet0/2.115            192.168.115.1   YES CONFIG up                    up
Ethernet0/2.116            192.168.116.1   YES CONFIG up                    up
Ethernet0/2.118            192.168.118.1   YES CONFIG up                    up
Ethernet0/2.119            192.168.119.1   YES CONFIG up                    up
Ethernet0/2.120            192.168.120.1   YES CONFIG up                    up
Ethernet0/2.121            192.168.121.1   YES CONFIG up                    up
Ethernet0/2.122            192.168.122.1   YES CONFIG up                    up
Ethernet0/3                unassigned      YES unset  up                    up
Ethernet0/3.210            192.168.210.2   YES CONFIG up                    up
Management0/0              unassigned      YES unset  down                  down
ciscoasa# sh ip address
System IP Addresses:
Interface                Name                   IP address      Subnet mask     Method
Ethernet0/0              Outside-Internet       122.56.33.108   255.255.255.248 CONFIG
Ethernet0/1.50           Servers                192.168.50.1    255.255.255.0   CONFIG
Ethernet0/1.202          Users                  192.168.202.1   255.255.255.0   CONFIG
Ethernet0/2.102          Pod2                   192.168.102.1   255.255.255.0   CONFIG
Ethernet0/2.103          Pod3                   192.168.103.1   255.255.255.0   CONFIG
Ethernet0/2.104          Pod4                   192.168.104.1   255.255.255.0   CONFIG
Ethernet0/2.105          Pod14                  192.168.105.1   255.255.255.0   CONFIG
Ethernet0/2.107          Pod1-Jeff              192.168.107.1   255.255.255.0   CONFIG
Ethernet0/2.110          Pod10                  192.168.110.1   255.255.255.0   CONFIG
Ethernet0/2.115          Pod15                  192.168.115.1   255.255.255.0   CONFIG
Ethernet0/2.116          Pod16                  192.168.116.1   255.255.255.0   CONFIG
Ethernet0/2.118          Pod18                  192.168.118.1   255.255.255.0   CONFIG
Ethernet0/2.119          Pod19                  192.168.119.1   255.255.255.0   CONFIG
Ethernet0/2.120          Pod20                  192.168.120.1   255.255.255.0   CONFIG
Ethernet0/2.121          Pod21                  192.168.121.1   255.255.255.0   CONFIG
Ethernet0/2.122          Pod22                  192.168.122.1   255.255.255.0   CONFIG
Ethernet0/3.210          ManageInternal         192.168.210.2   255.255.255.0   CONFIG
Current IP Addresses:
ciscoasa# sh ver
Cisco Adaptive Security Appliance Software Version 9.0(4)42
Device Manager Version 5.2(4)
Compiled on Fri 09-Sep-16 14:51 by builders
System image file is "disk0:/asa904-42-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 52 mins 25 secs
Hardware:   ASA5510-K8, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz,
Internal ATA Compact Flash, 256MB
Slot 1: ATA Compact Flash, 128MB
BIOS Flash AT49LW080 @ 0xfff00000, 1024KB
Encryption hardware device : Cisco ASA-55xx on-board accelerator (revision 0x0)
                             Boot microcode        : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode     : CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode       : CNlite-MC-IPSECm-MAIN-2.08
                             Number of accelerators: 1
 0: Ext: Ethernet0/0         : address is 0019.2f8f.210e, irq 9
 1: Ext: Ethernet0/1         : address is 0019.2f8f.210f, irq 9
 2: Ext: Ethernet0/2         : address is 0019.2f8f.2110, irq 9
 3: Ext: Ethernet0/3         : address is 0019.2f8f.2111, irq 9
 4: Ext: Management0/0       : address is 0019.2f8f.2112, irq 11
 5: Int: Not used            : irq 11
 6: Int: Not used            : irq 5
Licensed features for this platform:
Maximum Physical Interfaces       : Unlimited      perpetual
Maximum VLANs                     : 100            perpetual
Inside Hosts                      : Unlimited      perpetual
Failover                          : Active/Active  perpetual
Encryption-DES                    : Enabled        perpetual
Encryption-3DES-AES               : Enabled        perpetual
Security Contexts                 : 2              perpetual
GTP/GPRS                          : Disabled       perpetual
AnyConnect Premium Peers          : 2              perpetual
AnyConnect Essentials             : Disabled       perpetual
Other VPN Peers                   : 250            perpetual
Total VPN Peers                   : 250            perpetual
Shared License                    : Disabled       perpetual
AnyConnect for Mobile             : Disabled       perpetual
AnyConnect for Cisco VPN Phone    : Disabled       perpetual
Advanced Endpoint Assessment      : Disabled       perpetual
UC Phone Proxy Sessions           : 2              perpetual
Total UC Proxy Sessions           : 2              perpetual
Botnet Traffic Filter             : Disabled       perpetual
Intercompany Media Engine         : Disabled       perpetual
Cluster                           : Disabled       perpetual
This platform has an ASA 5510 Security Plus license.
Running Permanent Activation Key: 0x5e0a0774 0xa8506e82 0x64b12da8 0xa3187408 0x011be298
Configuration register is 0x1
Configuration last modified by enable_15 at 15:23:29.089 UTC Wed Oct 30 2019
ciscoasa# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is not set
C    192.168.122.0 255.255.255.0 is directly connected, Pod22
C    192.168.107.0 255.255.255.0 is directly connected, Pod1-Jeff
C    192.168.104.0 255.255.255.0 is directly connected, Pod4
C    192.168.121.0 255.255.255.0 is directly connected, Pod21
C    192.168.120.0 255.255.255.0 is directly connected, Pod20
C    192.168.105.0 255.255.255.0 is directly connected, Pod14
C    192.168.210.0 255.255.255.0 is directly connected, ManageInternal
C    192.168.110.0 255.255.255.0 is directly connected, Pod10
C    192.168.115.0 255.255.255.0 is directly connected, Pod15
C    192.168.202.0 255.255.255.0 is directly connected, Users
C    192.168.102.0 255.255.255.0 is directly connected, Pod2
C    192.168.119.0 255.255.255.0 is directly connected, Pod19
C    192.168.50.0 255.255.255.0 is directly connected, Servers
C    192.168.118.0 255.255.255.0 is directly connected, Pod18
C    192.168.103.0 255.255.255.0 is directly connected, Pod3
C    192.168.116.0 255.255.255.0 is directly connected, Pod16
ciscoasa#
try and add:
Oh yes. Silly me. I thought I'd put that policy in. I must not have applied it or saved it.
That did the trick - Thanks!
