My DHCP server is not giving ip to clients
My DHCP server pool is not providing ip to any clients of diff vlans
Below is the topology:-
I am using DHCP feature on window server 2k22 and created 7 pools for 7 different vlans and switch is 9300 series L3 switch, i created SVIs on it for each vlan.
when i trace packet between "switch and client" and "switch and server" i can clearly see that discover packet is reaching to server but not getting any offer or other packets.
i configured ip helper-address on each SVIs but still any client not getting ip.
TIA!!!!
10 Replies 10
M02@rt37
Hello @Sharanjeet_Kumar
Please attach in a zip file your packet tracer project.
Thanks.
Best regards
Thank you so much!!!
It got troubleshooted.
You're so welcome @Sharanjeet_Kumar
Best regards
Harold Ritter
Hi @Sharanjeet_Kumar ,
Does the DHCP server have a route to 192.168.1.1, 192.168.2.1, 192.168.3.1, etc pointing to 192.168.8.1? It does not need to be a specific route. It could be a default route.
This is required for the offer to be sent to the relay.
You mention it l3 sw so that OK.
Now are the server have SVI in this SW or in othet SW?
MHM
Server svi is in same switch as I have shown in the diagram/topology
Can you share config
What is model of this SW
MHM
Blue_Bird
Hi sharanjeet Kumar,
is "ip routing" command issued on multilayer switch global mode ?
Best regards
******* If This Helps, Please Rate *******
I already did as I mentioned L3 switch
Did server is assigned with gateway address...?
ip address: 192.168.8.2
subnet mask: 255.255.255.0
Default gateway: 192.168.8.1
if it is assigned... compare the following configuration...
hostname MLS
ip routing
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
switchport nonegotiate
interface FastEthernet0/2
switchport access vlan 20
interface FastEthernet0/3
switchport access vlan 30
interface FastEthernet0/4
switchport access vlan 40
interface FastEthernet0/5
switchport access vlan 50
interface FastEthernet0/6
switchport access vlan 60
interface FastEthernet0/7
switchport access vlan 70
interface FastEthernet0/8
switchport access vlan 80
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0001.42b4.3402
ip address 192.168.1.254 255.255.255.0
ip helper-address 192.168.8.2
interface Vlan20
mac-address 0001.42b4.3401
ip address 192.168.2.254 255.255.255.0
interface Vlan30
mac-address 0001.42b4.3403
ip address 192.168.3.254 255.255.255.0
interface Vlan40
mac-address 0001.42b4.3404
ip address 192.168.4.254 255.255.255.0
interface Vlan50
mac-address 0001.42b4.3405
ip address 192.168.5.254 255.255.255.0
interface Vlan60
mac-address 0001.42b4.3406
ip address 192.168.6.254 255.255.255.0
interface Vlan70
mac-address 0001.42b4.3407
ip address 192.168.7.254 255.255.255.0
interface Vlan80
mac-address 0001.42b4.3408
ip address 192.168.8.1 255.255.255.0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
also check in dhcp service must be enabled
Best regards
