my SUP7-E has problem with diagnostic level change
GH_Lee
hello
i got a SUP7-E on yesterday and i have to change diagnostic level minimum to complete.
so i changed license level Lanbase to Entservices (this sup's boot image is cat4500e-universalk9.SPA.03.08.07.E.152-4.E7.bin)
after reload, license level is changed with Entservices and can config diagnostic level but change diagnostic level minimum to complete and reload, license level goes down to Lanbase and diagnostic level goes down to minimum.
i tried almost 5 times but it doesn't works.
Is this my configuration problem or license problem?
when i change diagnostic level and reload, these logs came out.
*Jan 28 22:00:29.242: %C4K_IOSSYS-6-IMAGELEVEL: Supervisor booting in image level 'lanbase'
*Jan 28 22:00:29.293: %C4K_REDUNDANCY-6-INIT: Initializing as ACTIVE supervisor
*Jan 28 22:00:36.669: %C4K_SWITCHINGENGINEMAN-6-BFDINVALIDPACKETACLAPPLIED: Control plane protection against invalid BFD packets is applied
*Jan 28 22:01:15.168: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jan 28 22:00:17.209: %LICENSE-6-LICENSE_LEVEL: Module name = WS-X45-SUP7-E Next reboot level = lanbase and License = No license needed
*Jan 28 22:01:16.607: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 5 (WS-X45-SUP7-E S/N:  Hw: 2.1) is online
*Jan 28 22:01:16.607: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 7 (WS-X4148-RJ S/N: Hw: 3.1) is online
*Jan 28 22:02:20.421: %SYS-5-CONFIG_I: Configured from memory by consoleSystem has been configured
2 Accepted Solutions
GH_Lee
solved.
need to config license right-to-use activate on enable mode.
Hi @GH_Lee
Please visit the below link.
https://community.cisco.com/t5/networking-documents/cisco-catalyst-4500e-supervisor-7-e-and-7l-e/ta-p/3790065
BR,
Tayyab
*** Please rate all helpful responses and mark solutions***
GH_Lee
solved.
Hi @GH_Lee
BR,
Tayyab
Today I saw this log from Cisco 4500x-16 and I don't know why my core switch was reset
Plz help me what's happend
Core4500X_1#sho logging
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 19 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 19 messages logged, xml disabled,
filtering disabled
Exception Logging: size (8192 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 22 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (32768 bytes):
*Mar 18 04:55:35.183: %C4K_IOSSYS-6-IMAGELEVEL: Supervisor booting in image level 'ipbase'
*Mar 18 04:56:18.320: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar 18 04:56:20.295: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-C4500X-16 S/N: JAE19020D4X Hw: 1.1) is online
000004: *Mar 18 04:56:23.373: %SYS-5-CONFIG_I: Configured from memory by consoleSystem has been configured
000005: *Mar 18 04:56:23.497: %SYS-5-RESTART: System restarted --
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.06.00.E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 26-Jun-14 14:07 by prod_rel_team
000006: *Mar 18 04:56:27.669: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=1: Transceiver has been inserted
000007: *Mar 18 04:56:29.672: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=2: Transceiver has been inserted
000008: *Mar 18 04:56:31.670: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=3: Transceiver has been inserted
000009: *Mar 18 04:56:32.669: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=5: Transceiver has been inserted
000010: *Mar 18 04:56:32.669: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=6: Transceiver has been inserted
000011: *Mar 18 04:56:32.669: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=7: Transceiver has been inserted
000012: *Mar 18 04:56:34.668: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=10: Transceiver has been inserted
000013: *Mar 18 04:56:35.672: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=12: Transceiver has been inserted
000014: *Mar 18 04:56:35.672: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=13: Transceiver has been inserted
000015: *Mar 18 04:56:35.672: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=14: Transceiver has been inserted
000016: *Mar 18 04:56:35.673: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=15: Transceiver has been inserted
000017: *Mar 18 04:56:35.673: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=16: Transceiver has been inserted
000018: *Mar 18 04:56:39.776: %SFF8472-5-THRESHOLD_VIOLATION: Te1/3: Rx power low alarm; Operating value: -40.0 dBm, Threshold value: -13.9 dBm.
Core4500X_1#
Core4500X_1#
Core4500X_1#sho ti
Core4500X_1#sho clo
Core4500X_1#sho clock
*05:06:52.715 UTC Wed Mar 18 2020
