N3K-C3064 10G buffer problem or mikrotik?
patryklesniak
  • Hi, We have the setup
Cisco n3k-c3064 --> 10G --> BRAS Supermicro PPPoE server mikrotik x86 --> 10G --> OLT ZTE C300 uplink -->1G--> ONT -->1G--> Router AX1800-pppoe client
The problem is with speedtest on wifi on router AX1800 we canot go over 300mbps download and 700 upload with 10g configuration. Everyone told to us "the problem is with buffer, supermicro can be to fast" but no one can told to us how to fix this problem. The speedtest on wire is 940/940mbps, problem is only on wifi speedtest.
I tried to connect cisco->> 10g --> Supermicro pppoe server-->> 1g --> OLT ZTE-->1G-->ONT->>Ax1800. Speedtest on wifi up to 600/800mbps
But when I tried cisco->> 10g --> CCR1036 pppoe server-->> 10g --> OLT ZTE-->1G-->ONT->>Ax1800.
Speedtest on wifi is 800/800mbps.
Ccr was old BRAS and configuration pppoe server on routeros is the same on ccr1036 and supermicro (qos firewall etc.) I checked it first.
We have about 1500 pppoe client and avarge 5Gb/s transfer on supermicro with MT x86 then We cant a lot of change and test.
When We have ccr 1036 10g uplink and 4x 1g uplink to olt zte w dont see this problem but now yes.
  • Can you help us?
0 Replies 0
