N3k Login problem
Hi Dears i changed my username password by
username admin password asd123 role priv-15
Now when login by ssh switch donnot allow me login
How fix this
Please Help me
For n3k Follow this steps Is correct????
How Recovry N3000 Password
Used CTL+L or CRTL+C for enter Loader Mode
in loader mode enable recover mode
loader> cmdline recoverymode=1
Boot kickstart from OS
boot bootflash:nxos.7.0.3.I7.10.bin
switch(boot)# config terminal
switch(boot)(config)# admin-password new-password
switch(boot)(config)# exit
switch(config)# copy running-config startup-config
switch(boot)# load-nxos nxos.7.0.3.I7.10.bin
11 Replies 11
Mark Elsen
 - [email protected]            Do you still have console access ?  If so check logs when SSH-login is tried
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Mark makes a good suggestion about the console showing log messages that may help identify the issue. I would also point out that if the console access is successful it then provides a way to correct the issue, changing the config to other parameters.
Rick
Donnot any log on console
User Access Verification
E23-N3K-3064 login:
Console access Donnot show me anylog after enter username and password
Fastest recovery password for N3k ?? for short downtime ? any suggest ?
  - [email protected]   >....Console access Do not show me any logs after enter username and password
                                        To verify logs after you log on through the console issue the command : show logging
  M.
 I cannot login enter admin Password donnot login
  - [email protected]      Then checkout : https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/password_recovery/password-recovery-procedure-for-cisco-nxos.html
   M.
E23-N3K-3064 login:
do you use AAA (radius) to login ?
if local login is not configured as fall-backoption in the AAA configuration,
then you need to change the password on the login server, not on the switch itself!
Hi no AAA server change password and forget password IOS is :nxos.7.0.3.I7.10.bin for enter to boot mode use CTL+L ??? or ctl+C
pieterh
as far as I know ther is no escape character "ctrl-L"
maybe it refers to "ctrl-]" (right bracket) as the escape character when in a telnet session
rest of the procedure matches that in the document that @Mark Elsen has linked
