11-04-2020 06:07 AM
i have a n3k-c3064pq-10gx and i have a port-channel and i have around 10-12gbps bps on this port with 7-8m pps and i want to do a port mirror on another port channel or port to analyze the traffic, i want to knwo does it impact on cpu performance or it will use special asic and does not have any relation with cpu?
Thank you.
11-04-2020 07:09 AM
I do not believe mirroring has any issuye as i see - technically it should work.
If you are more concern, configure and monitoir is the suggest method.
11-04-2020 07:18 AM
but i am worry if copying data from a port channel to anotehr port afect on cpu,
