N5548-VTP and spanning tree issue
I am having issue with VTP incompatible on primary N5K
N5K-Primary#
vPC domain id                   : 53
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
Per-vlan consistency status     : success
Type-2 consistency status       : failed
Type-2 consistency reason       : VTP type-2 configuration incompatible
vPC role                        : primary, operational secondary
Number of vPCs configured       : 1
Peer Gateway                    : Disabled
Dual-active excluded VLANs      : -
Graceful Consistency Check      : Enabled
N5K-Primary## sh vtp status
VTP Status Information
VTP Version                     : 2 (capable)
Configuration Revision          : 4
Maximum VLANs supported locally : 1005
Number of existing VLANs        : 9
VTP Operating Mode              : Server
VTP Domain Name                 : <VTP domain not acquired/configured yet>
VTP Pruning Mode                : Disabled (Operationally Disabled)
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Enabled
MD5 Digest                      : 0x9B 0x75 0x57 0x77 0x42 0x0B 0xC8 0x61
Configuration last modified by 0.0.0.0 at 6-24-14 04:58:25
Local updater ID is 0.0.0.0
VTP version running             : 1
N5K-Primary# Sh spanning tree root
VLAN0001          4097 0023.04ee.be01       2    2   20  15    port-channel53
VLAN0300          4396 0023.04ee.be01       2    2   20  15    port-channel53
VLAN0302          4398 0023.04ee.be01       2    2   20  15    port-channel53
VLAN1000          5096 0023.04ee.be01       2    2   20  15    port-channel53
VLAN1001          5097 0023.04ee.be01       2    2   20  15    port-channel53
VLAN1007          5103 0023.04ee.be01       2    2   20  15    port-channel53
VLAN2701          6797 0023.04ee.be01       2    2   20  15    port-channel53
port-channel -53 is peer link going to secondary Nexus 5K
N5K-Secondary#
vPC domain id                   : 53
vPC role                        : secondary, operational primary
N5K-Secondary#Sh VTP status
Configuration Revision          : 0
Number of existing VLANs        : 5
VTP Operating Mode              : Transparent
VTP Domain Name                 : NNDC
MD5 Digest                      : 0xC0 0x0B 0x29 0xBC 0x09 0x92 0x40 0x4B
Configuration last modified by 0.0.0.0 at 0-0-00 00:00:00
N5K-Secondary# sh spanning-tree root
                                        Root  Hello Max Fwd
Vlan                   Root ID          Cost  Time  Age Dly  Root Port
VLAN0001          4097 0023.04ee.be01       1    2   20  15   port-channel253
VLAN0300          4396 0023.04ee.be01       1    2   20  15   port-channel253
VLAN0302          4398 0023.04ee.be01       1    2   20  15   port-channel253
VLAN1000          5096 0023.04ee.be01       1    2   20  15   port-channel253
VLAN1001          5097 0023.04ee.be01       1    2   20  15   port-channel253
VLAN1007          5103 0023.04ee.be01       1    2   20  15   port-channel253
VLAN2701          6797 0023.04ee.be01       1    2   20  15   port-channel253
port-channel-253 is port-channel going to nexus 7K's
Question:
- I am going to fix the VTP by changing VTP mode on primary N5K matching to secondary ...On secondary i have VTP as transparent.
- My question is " if i change VTP mode on primary does my spanning tree root changes ??"
- How can i make spanning tree root on N5K primary pointing to port-channel-253 instead of  port-channel 53
Reza Sharifi
It should not change the root.  Just make sure the primary device has lower id.
example:
spanning-tree vlan xxx priority 8192.
or if you are running mst
spanning-tree mst  xx priority 8192
and keep the secondary device as default.
