N5548UP AAA configuration problem
Ulrich Hansen
Level 2
Level 2
We recently switched a faulty N5548UP with a replacement and everything went fine, with the exception of one minor thing.
We're currently unable to authenticate using tacacs+.
When trying to enter the command 'aaa authentication login default group [groupname]', the following msg appears:
too big pss key or value size
could not update aaa configuration
We're running 5.0(3)N2(2b).
/Ulrich
nkarpysh
That seems to be known DDTS
CSCts71286 N7K, N5k and MDS AAA authentication issue
Please consider this workaround:
Workaround:
Copy the configuration, write erase, reload.
Procedure:
Switch# copy running-config bootflash:runconfig
Switch# write erase
Switch# reload
*** wait for reload ***
Switch# copy bootflash:runconfig running-config
Workaround:
Procedure:
Switch# write erase
Switch# reload
Hope this helps,
Nik
HTH,
Niko
nkarpysh
Workaround:
Procedure:
Switch# write erase
Switch# reload
Workaround:
Procedure:
Switch# write erase
Switch# reload
Hope this helps,
Nik
HTH,
Niko
Hi Nik,
Thanks for the info.
Reloading the switch however, is not really an option right now. Guess I'll have to schedule it later.
/Ulrich
I had this same issue last night. I write erased, rebooted, and copy the config back on and it worked fine. When I removed aaa commands and tried to put them back on, I had no luck. Write erase, reboot, and repaste config worked.
