N5K to 2960X stack CRC errors
M. Yashirli Vadrix
Frequent Visitor
Frequent Visitor
I have 4 stacks switch WS-C2960X connected to N5K-C5672 through VPC.
and from 2960X side use LACP portchannel.
CRC keeps increasing, only on connection to Nexus02, no CRC connection to Nexus01.
I've tried changing SFPs, changing Ports, changing Cables.
here my show commands..
SW01#sh cdp ne | b Device
Device ID Local Intrfce Holdtme Capability Platform Port ID
Nexus02 Gig 2/0/50 125 R S I C N5K-C5672 Eth 1/29
Nexus01 Gig 1/0/50 159 R S I C N5K-C5672 Eth 1/29
Total cdp entries displayed : 2
SW01#sh int gi 1/0/50 | inc error
SW01#sh int gi 2/0/50 | inc error
66930 input errors, 66450 CRC, 0 frame, 0 overrun, 0 ignored
SW01#
SW02#sh cdp ne | b Device
Nexus02 Gig 1/0/49 122 R S I C N5K-C5672 Eth 1/30
Nexus01 Gig 2/0/49 134 R S I C N5K-C5672 Eth 1/30
SW02#sh int gi 1/0/49 | inc error
43369 input errors, 42988 CRC, 0 frame, 0 overrun, 0 ignored
SW02#sh int gi 2/0/49 | inc error
SW02#
SW03#sh cdp ne | b Device
Nexus02 Gig 1/0/52 177 R S I C N5K-C5672 Eth 1/31
Nexus01 Gig 2/0/52 145 R S I C N5K-C5672 Eth 1/31
SW03#sh int gi 1/0/52 | inc error
2758140 input errors, 38073 CRC, 0 frame, 0 overrun, 0 ignored
SW03#sh int gi 2/0/52 | inc error
0 output errors, 0 collisions, 2 interface resets
SW03#
connection looks good, but not sure whats gonna happen in future.
12 Replies 12
Daniele Giordano
Level 11
Level 11
Are duplex configured in the same way on both devices?
Duplex mismatch can cause CRC.
Regards.
Check also this link:
https://community.cisco.com/t5/switching/nexus-5ks-to-2960-x-stack-crc-errors/td-p/2775071
CRC could be explained by the switching modality. The cut through mode forwards bad frames transparently from other ports.
So check CRC errors on all ports of the switch.
Regards.
i checked all ports, CRC appear on port that connected to N5K-02 and interface Port-channel
0 output errors, 0 collisions, 1 interface resets
808 input errors, 800 CRC, 0 frame, 0 overrun, 0 ignored --> Gi 2/0/50
808 input errors, 800 CRC, 0 frame, 0 overrun, 0 ignored --> Po1
SSW#
Yes.. all port configure at the same duplex
N5K-01# sh int e 1/29 | inc duplex
full-duplex, 1000 Mb/s, media type is 1G
N5K-02# sh int e 1/29 | inc duplex
SSW#sh int gi 1/0/50 | inc duplex
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
SSW#sh int gi 2/0/50 | inc duplex
Leo Laohoo
Don't put any filters on. We want to see the entire output.
Post the complete output to the command "sh interface <PORTS> CONTROLL".
here i post both ports connected to N5k01 & N5k02
i found there's different in FCS errors.
Let me repeat myself: DON'T PUT ANY FILTERS ON.
If it's a "secret" then change the IP address or raise a TAC Case.
got it..
on 2960X stack..
to n5k01to n5k01to n5k02to n5k02
Thanks for this.
The issue is the remote end of Gi 2/0/50.
CRC is "detected" by the receiving end. (You'll never find CRC from the transmission/sender.)
Look at the other side of Gi 2/0/50. If there is no CRC/FCS error then the issue is there. If CRC/FCS is also present (at the "other side") then the issue is the horizontal cabling.
NOTE: You've got other problems other than CRC. The 2960X is dropping packets.
Many thanks for the explanation Leo.. 🙂
i've tried to change port.
SW01 both port-channel member connect to N5K01, after 30mins await no more CRC from SW01.
i believe should be no problem with the SFP and cabling.
but this.. SW02 both port-channel member connect to N5K02, both ports get CRC.
and i checked all switch port connect to N5K02 got CRC.
both nexus running same System version: 7.1(0)N1(1b)
sw01sw01sw01sw01sw02sw02sw02sw02
Here's one way of testing: Swap the fibre between Gi 1/0/50 and Gi 2/0/50.
If the CRC errors go to Gi 1/0/50 then we are sure it's an issue. Since this is fibre, get someone to do an OTDR test of the entire link.
By the way, is the fibre link between the two OM3/OM4?
And how is this path linked together?  Is it:
2960 stack < --- > patch cord < -- > FOBOT < -- > fibre optic cable < -- > FOBOT < -- > patch cord < -- > Nexus?
(I want to know how many patch cord/cords and/or how many jumpers, etc.)
for temporary, i move all portchannel member some stack switch connection to N5K01.
since this is production, and previously use cat4509 was normal, migrate to N5K last week.
the fiber type is OM3, link path is 2960stack <---> Nexus in single patch cord.
anyway, thanks a lot Leo 🙂
