N7K, F248XP-25E, v6.2.14 - Netflow (- BFD) problem
Hello Community.
I have a Nexus 7009 with SUP2 and F248XP-25E running on NX-OS 6.2.14.
I tried to configure Netflow and activate it on a SVI; see config bellow.
When activating this on a Interface VLAN3192 I receive the following message:
N7K-2(config-if)# ip flow monitor NetFlow-Monitor input sampler 4956-packets
Recommended sampler is 1 out-of 4956 to avoid rate limiting.
An additional 1:100 sampler, over the configured sampler is applicable for F2/F2e ports
Verify failed - Client 0x84000146, Reason: Tcam Allocation Failure,  : Netflow Sampler (SVI), BFD, Interface: Vlan3192
N7K-2(config-if)#
I found a comparable Topic with DHCP Relay and Netflow
https://supportforums.cisco.com/discussion/11799601/nexus-7k-f248xp-25-dhcp-relay-and-netflow-Problem
Has please anyone an idea whats going wrong in my Setup?
Is BFD and Netflow on the same SVI not supported.
I have not found some hints in the Manual or release notes on this combination.
Any idea is highly appreciated.
Thank you
Karlheinz
flow timeout active 60
flow exporter NetFlow-to-Orion
  destination 10..x.x.x
  transport udp 2055
  source Vlan1800
  version 9
    template data timeout 60
flow record OrionNetFlow
  match ipv4 source address
  match ipv4 destination address
  match ip protocol
  match ip tos
  match transport source-port
  match transport destination-port
  collect counter bytes
  collect counter packets
  mode 1 out-of 4956
  description NetFlow-to-Solarwinds
  record OrionNetFlow
Rajeshkumar Gatti
By default both bfd and s-netflow are not supported on the same svi. There is a knob available in the code you are running that allows these features to now coexist. You will have to configure the following command in the default vdc -
hardware access-list resource feature bank-mapping
I would recommend you to go through the document below as well
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/6_x/nx-os/security/configuration/guide/b_Cisco_Nexus_7000_NX-OS_Security_Configuration_Guide__Release_6-x/b_Cisco_Nexus_7000_NX-OS_Security_Configuration_Guide__Release_6-x_chapter_01110.html#concept_C64B6A15DAD848B18597CCF54B2EA020
Hope this helps resolve your issue.
-Raj
