N7K F3 & M1 cards on same VDC
We have a pair of N7K running in stand alone mode, we want to change the operation mode to support VPC, proucred N7K-F348XP-25= modules to get 10G ports, presently switches are populated with N7K-M148GT-11L modules, Can I put F3 & M1 in default VDC?
If not in the default VDC then is there any other way to put these cards in same vdc?
Gopal
Reza Sharifi
You should not have any issues putting both modules in the global VDC. Global is the main default VDC.
According to the following chart M1 and F3 in the same VDC is not supported. What do you think?
Thank you
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/nexus7000/sw/matrix/technical/reference/Module_Comparison_Matrix.pdf
