07-02-2018 11:55 PM - edited 03-08-2019 03:32 PM
We see some rate-limiter dropped packets with the show hardware rate-limiter command. L3 ttl and L3 glean are showing dropped packets.
R-L Class Config Allowed Dropped Total
L3 ttl 500 1911655 5266 1916921
L3 glean 100 1412552 3393 1415945
Since we are having some issues with Citrix Netscaler failover, we believe this could be due to dropped arp.
Changing the L3 ttl and glean value, will this impact trafficflow or could this command be done while production traffic is flowing in the corenetwork?
I can see that the values can be set between 0 and 30000. What value would be "safe" to set? The n7k cpu have an average of 10-15% utilization.
thx
Geir
07-03-2018 12:24 AM
rather than changing the values you might want to use the ip glean throttle feature, which should get rid of the drops:
N7K(config)#hardware ip glean throttle
07-03-2018 12:33 AM
Thx for the quick reply.
The hardware ip glean throttle is a "safe" command to run while networktraffic is flowing in our corenetwork? Or should we do it in a maintenance window?
Geir
07-03-2018 12:43 AM
the feature installs a drop index, depending on what you are running on your network, I would, to be on the safe side, make the change after hours..
09-26-2018 12:29 AM
Did run the command:
But it didn't seem to solve the issue. So we need to look more into this.
Read that as a first step could be disable ip redirects on your svi Interfaces. Think this is already done, but will double check that.
Geir
