02-03-2022 04:38 AM
Hello
I have a question regarding my small 10gbe network.
I have a 9396TX switch with a N9K-M6PQ 40gbe module. I need to find a proper breakout cable that I can use to connect the switch to C7000 blade system and hp proliant 380p G8 server.
Can I use any Cisco 40Qsfp to 4x 10gbe sfp+ cable or I need a special one?
Solved! Go to Solution.
02-03-2022 08:37 AM
Any Cisco or Cisco compatible breakout cable should work. I use these guys and they are pretty good.
https://www.fs.com/products/30906.html
02-03-2022 08:37 AM
02-05-2022 12:28 AM
i have already contacted them before asking if the cable is compatible . But they replied that they need to check first and asked for the server and blade 10gbe cards data .
But as your already tried it . i will follow your advice .
Many Thanks for the help
