NAT and Access Lists help
Katsikantais
I would like some help with 2801. I can ping from router e.g. 8.8.8.8 but PC's
doesn't have internet and they can't ping e.g 8.8.8.8.
I think the problem is with nat and access lists and I cant find it.
I have the 2801 as second router connected to main from fe0/0. I can ping the
main router (172.20.0.1/21).
fe0/1 is for local lan (192.168.100.254/24).
Here is my setup...
Current configuration : 1314 bytes
version 12.4
hostname XXXXXXX
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$9h9a$j0J3TS8EUZaI/zLH03EK//
enable password XXXXXXXX
no aaa new-model
no network-clock-participate wic 1
ip source-route
ip cef
no ipv6 cef
voice-card 0
archive
log config
hidekeys
controller E1 0/1/0
shutdown
interface FastEthernet0/0
description wan.interface
ip address 172.20.0.6 255.255.248.0
ip nat outside
ip virtual-reassembly
speed auto
half-duplex
no mop enabled
interface FastEthernet0/1
description local.interface
ip address 192.168.100.254 255.255.255.0
ip nat inside
speed auto
half-duplex
no mop enabled
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.20.0.1
no ip http server
ip nat inside source list nat interface FastEthernet0/0 overload
access-list 10 permit 192.168.100.0 0.0.0.255
dialer-list 1 protocol ip permit
disable-eadi
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
password XXXXXXXX
login
scheduler allocate 20000 1000
Any suggestions what to fix please.
Thank you.
Reza Sharifi
Can you change your config to refer to to the access list number?
to
ip nat inside source list 10 interface FastEthernet0/0 overload
and test again?
Reza Sharifi
to
and test again?
Thanks for your replay.
I works now...
I tested using static ip's in 3 pc's and all have internet.
Thanks a lot
Glad to know its all working for you.
Good Luck!
