Cisco 3850 Switch Prompt Recovery using XMODEM
nabeelcse07
HI,
I am having a Cisco 3850 Switch with Switch Prompt: and I am trying to get it out of this by using xmodem.
I am using BAUD rate 115200 and I am getting the following output when I give command "copy xmodem: flash:imagename
switch: flash_init
Initializing Flash...
...The flash is already initialized.
switch: copy xmodem: flash:cat3k_caa-universalk9.16.05.01a.SPA.bin
Begin the Xmodem or Xmodem-1K transfer now...
CC
Starting xmodem transfer. Press Ctrl+C to cancel.
Transferring cat3k_caa-universalk9.16.05.01a.SPA.bin...
flash:cat3k_caa-universalk9.16.05.01a.SPA.bin: no such device
any suggestion what could be the reason, I am not able to do it.
NA
Reza Sharifi
Did you try sending the file/image from your laptop/pc to the emulator?
Have a look at this link for instructions:
https://supportforums.cisco.com/blog/151336/loading-ios-switch-xmodem
