NAT ASA 5505 help
smavashev
I'm trying to translate my inside network of 192.168.20.0 to my outside ISP address on ASA 5505. The ping from all hosts to 4.2.2.2 works, but
it still only let's one address out to translate.
My configuration is:
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
still doesn't work. Some help would be great !
cadet alain
What do you mean by that? the 2 commands you typed are correct.
Regards.
Alain
I'm sorry. What I meant was the commands are correct.
I typed in show xlate and I see translations for both of my stations. However one station can ping the DNS server and 1 can't. Both stations are getting dhcp from 3550 switch for lan 192.168.20.0 255.255.255.0. Both ipconfig's list the same DNS server. But my laptop can't ping the DNS server and my PC can. I though maybe it's a conflict with a wireless network on my laptop but ping 4.2.2.2 works. What is the problem ?
Sergei.
I suggest you start wireshark on both machines and sniff  traffic then save the capture file and post it here.
Regards.
Alain
