NAT configuration issues on 6509
poirot1967
Got kind of a BIG headache on this one. I know it must be simple, but I am just not seeing it.
I have 2 vlans, vlan1 and vlan3. Vlan 1 is a public vlan that connects to the outside world. Vlan3 is non-routable. I configured a PAT. It looked great in the test lab, but is not working in the shop. I can ping the gateway from the switch, but not past the gateway, in the console. Here is a snipet of the config :
interface Vlan1
ip address xxx.xxx.xxx.xxx 255.255.254.0
ip nat outside
no ip route-cache
interface Vlan3
ip address 192.168.32.1 255.255.254.0
ip nat inside
no ip route-cache
ip default-gateway 137.187.44.1
ip nat pool niscpool 137.187.44.105 137.187.44.106 prefix-length 23
ip nat inside source list 1 pool niscpool overload
access-list 1 permit 192.168.32.0 0.0.0.255
access-list 1 permit 192.168.33.0 0.0.0.255
Here is the route table
Gateway of last resort is not set
1.0.0.0/32 is subnetted, 1 subnets
C 1.1.1.1 is directly connected, Loopback0
137.187.0.0/23 is subnetted, 1 subnets
C 137.187.44.0 is directly connected, Vlan1
C 192.168.32.0/23 is directly connected, Vlan3
Any info would be appreciated!!
Poirot
mohammedmahmoud
Level 11
Level 11
This is simply that you don't have a default route, the ip default-gateway should only be used when ip routing is disabled, please configure a default route using "ip route 0.0.0.0 0.0.0.0 x.x.x.x" and it should work fine.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
mohammedmahmoud
Level 11
Level 11
Mohammed Mahmoud.
That was it! I knew it had to be something simple that I was just not seeing.
Thank You Very MUCH!!!
Poirot
Hi Poirot,
You are very welcomed, i am very glade that we have helped you, and thanks for using the rating system, and please do come back if you have further questions.
BR,
Mohammed Mahmoud.
