SDM Prefer Question
cisconoobie
Level 2
Level 2
I have a Stack of 2 switches that has IP Routing enabled. This stack hosts my server farm as well as does the intervlan routing.
Core#show ip route summary
IP routing table name is Default-IP-Routing-Table(0)
IP routing table maximum-paths is 32
Route Source Networks Subnets Overhead Memory (bytes)
connected 0 17 1088 2584
static 1 0 64 152
internal 1 1172
What template should I use?
sdm prefer routing?
sdm prefer vlan?
or leave is as the default?
Edison Ortiz
Sdm prefer vlan would disable unicast routing so I will advise against it. Sdm prefer default should meet your needs.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225see/scg/swsdm.htm
