NAT issue on 3850
sivam siva
Level 3
Level 3
HI
Can anyone help me to solve the nat issue?
below is a simple diagram that I used. (all real cisco equipment Router: cisco asr 1k, SW: 3850 Version 03.07.05.Enattopo.PNGSW config: I have configured G1/0/1 and G1/0/2 as L3 port and assigned IP address as per the diagram, IP routing is enabled, and no static and dynamic routing.
Router config: enabled g0/0/1 and assigned IP.
PC config: assigned IP as per the diagram and G1/0/1 is the gateway of PC.
Below is the NAT config:SWCONFIG.PNG
I have tried to check the NAT from the switch (by pinging the router from 192.168.20.1):
swconfig1.PNGThe address was translated and so router replied to 121.241.200.238, there is no issue, everything was working fine!.
When I tried to ping from PC:swconfig2.PNG
request timed out, NAT is not working.
Is this bug?
Please refer below running-config if needed.
Switch#
Switch#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is not set
121.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 121.241.200.236/30 is directly connected, GigabitEthernet1/0/2
L 121.241.200.238/32 is directly connected, GigabitEthernet1/0/2
192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.20.0/24 is directly connected, GigabitEthernet1/0/1
L 192.168.20.1/32 is directly connected, GigabitEthernet1/0/1
Switch#
Switch#sh run
Building configuration...
version 15.2
boot system switch all flash:cat3k_caa-universalk9.SPA.03.07.05.E.152-3.E5.bin
switch 1 provision ws-c3850-12x48u
ip routing
interface GigabitEthernet1/0/1
no switchport
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface GigabitEthernet1/0/2
no switchport
ip address 121.241.200.238 255.255.255.252
ip nat outside
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface Vlan1
ip address 10.0.0.1 255.0.0.0
ip nat inside source list LAN interface GigabitEthernet1/0/2 overload
ip access-list standard LAN
permit 192.168.20.0 0.0.0.255
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
Siva
2 Accepted Solutions
Are running NAT on the 3850 switch? The 3850 series switches don't support NAT even though the commands are available,
You are absolutely right @Reza Sharifi
I had not noticed the model of the device.
This was discussed in another discussion as well:
https://community.cisco.com/t5/switching/3850-nat/td-p/2479841
5 Replies 5
network_geek
The standard access-list you have configured. Where have you applied it?
luis_cordova
Hi @sivam siva ,
Try this:
Switch(config)#ip route 0.0.0.0 0.0.0.0 121.241.200.237
sivam siva
Level 3
Level 3
@network_geek
Thanks for the reply
you can see in the "sh ip nat statistics" output, that I have called ACL for NAT.
@luis_cordova
I'm trying to reach the destination which is directly connected to the switch, also you can verify in the "sh ip route" output that switch has a route to 121.241.200.236/30.
Siva
