01-21-2016 08:46 AM - edited 03-08-2019 03:29 AM
I have cisco ME3600X-24FS-M running a metro IP access image (me360x-universalk9-mz.122-52.EY4). there is need to enable NAT services on the device but i discovered that it has limited NAT functionality. It has no support for STATIC NAT and NAT POOL. Again, even with NAT overload (PAT), it still does not function as expected. A laptop physically connected on the same VLAN and subnet as the inside interface does not get translated. but a ping test to the internet (OUTSIDE) sourced from the actual inside interface on the ME3600X gets translated. I find this intriguing. Any ideas on how to resolve this ?
hostname#sh ver
Cisco IOS Software, ME360x Software (ME360x-UNIVERSALK9-M), Version 12.2(52)EY4,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 14-Feb-12 05:56 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x0221E480
ROM: Bootstrap program is WHALES boot loader
BOOTLDR: ME360x Boot Loader (ME360X-HBOOT-M), Version 12.2 [sourdutt-loader_release_ledfix 100]
hostname uptime is 7 weeks, 22 hours, 51 minutes
System image file is "flash:/me360x-universalk9-mz.122-52.EY4/me360x-universalk9-mz.122-52.EY4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: MetroIPAccess
License Type: Permanent
Next reload license Level: MetroIPAccess
cisco ME-3600X-24FS-M (PowerPC8572) processor (revision B0) with 1015808K/32760K bytes of memory.
Processor board ID FOC!!!!!!!!!!!!!
Last reset from power-on
15 Virtual Ethernet interfaces
25 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
1536K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 0C:68:03:C6:66:00
Motherboard assembly number : 73-12693-07
Motherboard serial number : FOC!!!!!!!!!!!
Model revision number : B0
Motherboard revision number : B0
Model number : ME-3600X-24FS-M
System serial number : FOC!!!!!!!!!
Top Assembly Part Number : 800-32951-01
Top Assembly Revision Number : C0
Version ID : V01
CLEI Code Number : IPML500KRA
01-21-2016 11:26 AM
I just learnt something! I didn't think this platform could even do NAT.
The software release you are using is really old. I can't even find it available for download anymore from Cisco's site - which is a concern. This means it is no longer a supported software version.
If it was me I would personally upgraded to a supported version of code on this platform first, such as 15.4(3)S4 - which is a gold star release version. Your problem may have been solved years and years ago.
