NAT Issues
rashad.exe
Level 2
Level 2
HI
i am trying to apply NAT on cisco CSR 1000V
when i apply the NAT i can to internet from any client in the local network but i can't browse the internet
so any on can help about the problem
Router#sho run
Router#sho running-config
Building configuration...
no aaa new-model
ip cef
username admin privilege 15 password 0 nothing
archive
 log config
  hidekeys
interface FastEthernet0/0
 ip address 172.20.0.10 255.255.0.0 secondary
 ip address 172.17.0.2 255.255.0.0
 ip nat inside
 ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0
 ip address 10.10.10.10 255.255.255.252
 ip nat outside
 no fair-queue
interface Serial0/0/1
 no ip address
 shutdown
 clock rate 2000000
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.10.10.9
ip http server
ip nat pool zozo x.x.x.x x.x.x.x netmask 255.255.255.224
ip nat inside source list 100 pool zozo overload
access-list 100 permit ip 172.17.0.0 0.0.255.255 any
access-list 100 permit ip 172.20.0.0 0.0.255.255 any
control-plane
line con 0
line aux 0
line vty 0 4
 login local
 transport input telnet
 transport output telnet
scheduler allocate 20000 1000
end
Router#
10 Replies 10
Reza Sharifi
Are you doing NAT from private to private IP or the serial interface has a public IP?
 ip nat outside
 no fair-queue
hi
yes the serial interface public ip address
(sorry i forget to change it in the post )
If you can connect to Internet but you can not browse, it could be a DNS issue. Can you try accessing a web site by IP.
so 2 tests:
1-from you LAN if you can ping 8.8.8.8 you have internet connectivity.
if above works go to step number 2
2-http://74.125.236.84
This is Google IP
hi
i try it but still no browsing access
do you think i have problem because it CSR 1000V on VMware
by the way i user this router as VPN router and its working with out any problems
thanks
So are you able to ping 8.8.8.8 from your LAN?
yes i can ping from my local network to 8.8.8.8
Ok, so you have Internet access.
to test, on your laptop add a DNS entry of 8.8.8.8 (this is Google DNS)  and than try to browse www.google.com
I have never used the CSR 1000v, but I don't think that is the problem because you already have Internet access.
i try it in in the first step and still have the same problem
Can you delete "ip virtual-reassembly" from interface fa0/0 and s0/0/0 and test again?
devils_advocate
Level 11
Level 11
If you can ping an internet address but are not able to browse to a website then its likely a DNS issue.
What device is doing your DNS?
If you set your dns server to 8.8.8.8 does it work?
