Nat lab Question
aaron.cowell.au
Sorry to bother again. I am setting up a lab and am having troble getting nat to work. The startup config files are below. When pinging 10.0.0.254 from router R6 I get the following debug information on nat router.
*Mar  1 18:58:04.851: NAT: translation failed (A), dropping packet s=192.168.0.254 d=10.0.0.254
*Mar  1 18:58:04.955: NAT: translation failed (A), dropping packet s=192.168.0.254 d=10.0.0.254
R5#
*Mar  1 18:58:06.987: NAT: translation failed (A), dropping packet s=192.168.0.254 d=10.0.0.254
*Mar  1 18:58:07.107: NAT: translation failed (A), dropping packet s=192.168.0.254 d=10.0.0.254
R5#
*Mar  1 18:58:09.055: NAT: translation failed (A), dropping packet s=192.168.0.254 d=10.0.0.254
upgrade fpd auto
version 12.4
hostname R4
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
memory-size iomem 0
archive
log config
hidekeys
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface GigabitEthernet1/0
ip address 10.0.0.254 255.255.255.0
negotiation auto
router eigrp 10
network 10.0.0.0
auto-summary
router rip
network 10.0.0.0
neighbor 10.0.0.1
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
line con 0
exec-timeout 0 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
upgrade fpd auto
version 12.4
hostname R5
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
memory-size iomem 0
archive
log config
hidekeys
no ip address
shutdown
duplex half
ip address 10.0.0.1 255.255.255.0
ip nat outside
ip virtual-reassembly
negotiation auto
interface Serial2/0
ip address 192.168.0.1 255.255.255.0
ip nat inside
serial restart-delay 0
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Serial2/4
no ip address
shutdown
interface Serial2/5
no ip address
shutdown
interface Serial2/6
no ip address
shutdown
interface Serial2/7
no ip address
shutdown
router eigrp 10
network 10.0.0.0
network 192.168.0.0
auto-summary
router rip
network 10.0.0.0
network 192.168.0.0
neighbor 192.168.0.254
neighbor 10.0.0.254
no ip http server
ip nat pool tester1 10.0.0.1 10.0.0.1 netmask 255.255.255.0
ip nat inside source list 99 pool tester1
access-list 99 permit any
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
line con 0
exec-timeout 0 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
upgrade fpd auto
version 12.4
hostname R6
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
memory-size iomem 0
archive
log config
hidekeys
no ip address
shutdown
duplex half
interface Serial1/0
ip address 192.168.0.254 255.255.255.0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
router eigrp 10
network 192.168.0.0
auto-summary
router rip
network 192.168.0.0
neighbor 192.168.0.1
no ip http server
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
line con 0
exec-timeout 0 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
5 Replies 5
cadet alain
can you try this:
ip nat inside source list 99 pool tester1 overload
no access-list 99
access-list 99 permit 192.168.0.0 0.0.0.255
Regards.
Alain
Did nothing same result.
You may focus on the routing. You should use "no auto-summary" on all RIP routers as well. You may need to specific which networks have to be advertised for each routing protocol. You may also need to do redistribution.
Toshi
aaron.cowell.au
Ok found solution as below:
ip nat pool tester1 10.0.0.1 10.0.0.2 netmask 255.255.255.0
But what do I do if I only want one ip address as the nat translation. Because I though this would be two 10.0.0.0.1 and 10.0.0.2
Also I can ping into the natted address so I can ping 10.0.0.254 from 192.168.0.254 and the reverse. I thought that with nat the inside address were not accessable from the outside interface? Does this make sense. How to I create this behaviour.
What I want to achive is I will have a public ip address from my ISP and want to NAT it to a private network. I do not want outside public ip address being able to ping the internal ip address.
upgrade fpd auto
version 12.4
hostname R5
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
memory-size iomem 0
archive
log config
hidekeys
no ip address
shutdown
duplex half
ip nat outside
negotiation auto
interface Serial2/0
ip nat inside
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Serial2/4
no ip address
shutdown
interface Serial2/5
no ip address
shutdown
interface Serial2/6
no ip address
shutdown
interface Serial2/7
no ip address
shutdown
router eigrp 10
network 10.0.0.0
network 192.168.0.0
auto-summary
router rip
network 10.0.0.0
network 192.168.0.0
neighbor 10.0.0.254
no ip http server
ip nat source list 99 pool tester overload
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
line con 0
exec-timeout 0 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
do clear ip nat trans
no ip nat pool tester1 10.0.0.1 10.0.0.2 netmask 255.255.255.0
no ip nat source list 99 pool tester overload
no ip nat inside source list 99 pool tester1
ip nat source list 99 interface gig1/0
Regards.
Alain
