NAT on 6509 with Supervisor 2T
John Supple
Need some help (I'm getting desperate) for setting up NAT on a 6509 with a sup 2T - I'd like to set up a couple of /21 private networks and NAT them out to a single public IP address.  I'd also like to use our central DHCP server for DHCP.
I'm having trouble finding good advice on this.  Anyone set this up recently?
Hi John,
So I can provide a sample configure based on the following assumptions
  1. DHCP server is connected and working & configured for your new subnets
  2. DHCP server's ip address is 10.0.0.1
  3. Your internet connection is already working
  4. Your public ip address terminates on Gi1/1
  5. I create two vlan's 11 & 12 with /21 ranges
  6. I use standard acl 50 note the acl matches a /20 to aggregate the 2 x /21's
So you will need to change the above assumption in my sample to suit your needs
configure terminal
vlan 11
name Private-Net1
vlan 12
name Private-Net2
interface vlan 11
ip address 192.168.0.1 255.255.248.0
ip nat inside
ip helper-address 10.0.0.1
interface vlan 12
ip address 192.168.8.1 255.255.248.0
ip nat inside
interface Gi1/1
ip nat outside
exit
access-list 50 permit 192.168.0.0 255.255.240.0
ip nat inside source list 50 interface Gi1/1 overload
If you have any questions please let me know, If you find this answer help and it you feel it's correct please remember to mark it as a correct answer to help future readers.
After the initial address translation the translation of subsequent packets in a flow should be translated in hardware, However if you find there is a performance impact as a result of performing NAT on the device then I would suggest reading
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/63992-6k-high-cpu.html#Nat
Thank you Mark.  Is it necessary for the public IP to be on a physical interface?  I'd like to have it NAT through an IP on a vlan.  Is that doable?
John
John
Yes you should be able to use an SVI instead of a L3 port.
Jon
Hi John
Yes you can use an SVI/Vlan interface as Jon has pointed out,
Just configure it as normal and add the ip nat inside statement to it
you would also need to change the line
to something like
ip nat inside source list 50 interface Vlan88 overload
When Vlan 88 has your public ip
