NAT on Layer 3 switches?
wong_mike
Hi experts,
Any work-around on how to implement NAT on layer3 switches? (e.g. 4507 with SuperEngine 5 or 4948 or 3750)
Thanks in advance.
5 Replies 5
Edison Ortiz
NAT is only supported on 6500 Layer3 switches. The workaround in your case is, get a router to perform this task.
Thanks for your prompt reply.
I'm still researching on this topic.
What about the VRF-lite technology? How can I implement it?
Cheers
Please see the following document:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_37s/config/vrf.htm
thank you
Malik
Abrar Malik
You can't do if you have no any router. or higher l3 sw.
Malik
