Nat ona a Stick
kwojtyra
is it possible to make NAT between two VLAN, and tranlate address from one side to the other and opposite. For example 10.10.10.1 witch comes from vlan 1 transle it to 10.10.20.1. And from the VLAN 2 address 10.10.20.1 translate to 10.10.10.1. Is it possible. Does it will give duplicate addresses? And if it is possible how to make that on subinterfaces.
6 Replies 6
kwojtyra
-> yes this is possible
-> yes you could end up with double addresses
but you could  split the range like
     10.10.10.1-10.10.10.126->      10.10.20.1-10.10.20.126
     10.10.20.129-10.10.20.254 ->      10.10.10.129-10.10.10.254
-> just apply the "ip nat inside/outside" command on the subinterface
Hi, that's how looks my router configuration, we need to test how it works so I made Router on a Stick, with trunk on one port in router with subinterfaces. We connected it to switch and then to PC1 and PC2.
Building configuration...
interface GigabitEthernet0/0/0
no ip address
negotiation auto
interface GigabitEthernet0/0/0.412
encapsulation dot1Q 412
ip address 10.10.10.254 255.255.255.0
ip nat enable
interface GigabitEthernet0/0/0.512
encapsulation dot1Q 512
ip address 10.10.20.254 255.255.255.0
ip nat enable
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface Vlan1
no ip address
interface Vlan412
no ip address
interface Vlan512
no ip address
ip nat inside source static 10.10.10.1 10.10.20.1
end
I read that if I do this on subinterfaces i need to do command ip nat enable only on both interfaces. My PC1 is 10.10.10.1 and PC2 is 10.10.20.7. I would like to configure NAT so when i ping from PC1 to PC2, I would see in wireshark on PC2 that source address of the ping is not 10.1 but 20.1, so after the translation.
make these changes
ip nat inside
ip nat outside
Ok, now I change it, what next?
Hello
Why?
Kind Regards
Paul
