NAt overload does not work simultaneously on two VRF subinterfaces
Problem description:
We are running NAT overload over two Sub interfaces, each with another VRF.
When the customer wants to start an ftp or another TCP session, the NAT translation doesn't run on both interfaces simultaneous.
When the first ftp transmission is finished the second starts transmitting when the first connection is lost.
NAT works allright independent of the IOS that is inatalled but not through two Virtual interfaces at the same time.
Yesterday I tried to start a simultanious ping over the two interfaces, this also didn't work.
It looks like there is only one NAT process accepted.
Server Side
interface GigabitEthernet0/0.103
description GigabitEthernet0/0.103 dot1q vlan id=103 (C2000-CORE)
encapsulation dot1Q 103
ip vrf forwarding V596:VRF-c2000-core
ip address 10.190.236.253 255.255.255.0
ip nat outside
ip virtual-reassembly
interface GigabitEthernet0/0.104
description GigabitEthernet0/0.104 dot1q vlan id=104. (C2000-SPECIALS)
encapsulation dot1Q 104
ip vrf forwarding V597 :VRF-c2000-specials
ip address 13.17.12.253 255.255.255.0
ip nat outside
interface GigabitEthernet0/1.103
description GigabitEthernet0/1.103 dot1q vlan id=103. (C2000-CORE)
ip address 10.137.195.42 255.255.255.252
ip nat inside
interface GigabitEthernet0/1.104
description GigabitEthernet0/1.104 dot1q vlan id=104. (C2000-SPECIALS)
ip address 10.137.197.42 255.255.255.252
ip nat inside
ip nat inside source list 1 interface GigabitEthernet0/0.103 vrf V596:VRF-c2000-core overload
ip nat inside source list 2 interface GigabitEthernet0/0.104 vrf V597 :VRF-c2000-specials overload
access-list 1 remark DRIE VRF-CORE
access-list 1 permit 192.168.201.0 0.0.0.255
access-list 1 remark HILVRF-CORE
access-list 1 permit 192.168.211.0 0.0.0.255
access-list 2 remark DRIE VRF-SPECIALS
access-list 2 permit 192.168.202.0 0.0.0.255
access-list 2 remark HIL VRF-SPECIALS
access-list 2 permit 192.168.212.0 0.0.0.255
Customer side
IOS: "flash:c2800nm-spservicesk9-mz.124-12.bin"
description Gigabitethernet0/1.103 dot1q vlan id=103. (C2000-CORE)
ip address 192.168.212.254 255.255.255.0
no cdp enable
description Gigabitethernet0/1.104 dot1q vlan id=104. (C2000/SPECIALS)
ip address 192.168.202.254 255.255.255.0
no cdp enable
description Gigabitethernet0/1.103 dot1q vlan id=103.(C2000-CORE)
ip address 10.137.195.18 255.255.255.252
no cdp enable
description Gigabitethernet0/1.104 dot1q vlan id=104.(C2000-SPECIALS)
no cdp enable
desensitized
Community Member
The IP address you set to the subinterfaces 1.103 and 1.104 for the customer side are the exact same. Both are 10.137.195.18 which is unacceptable in a network.
None of the internet Ip addresses assigned to the interfaces are correct. I have just given fake ip adresses as this is a public forum. I have seen to it that there is not ip address conflict or any other issue with the IP addresses.
the NAT works fine as I have mentioned earlier. But only issue is not on both the VRF interfaces simultaneously.
So just want to know if there is any limitation on the NAT processes.
Hello Usman,
give a look at the following document
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iadnat_mpls_vpns_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1046889
I see in the steps the configuration of static routes in VRF. These can play a role for the feature.
Hope to help
Giuseppe
