NAT pool issues with route-maps
Stratocomp
Hello all, I have had a hard time trying to get this figured out.  Here is what I have.  A 1841 router and a 3560g L2 switch.  I have a block of 12 IP's from my ISP that I can use.  What I want to accomplish is each of the 11 external ip's will be mapped to a user subnet.  I am utilizing FA0/0 as my outside interface with the first external IP.  then I have fa0/1.xx for sub interfaces.  These sub interfaces match up with a vlan on the switch which is then trunked down to a server.
Cisco 1841
logging buffered 16384 debugging
aaa new-model
aaa authentication login default local
aaa session-id common
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1 10.10.10.49
ip dhcp pool 66
   import all
   network 10.66.66.0 255.255.255.0
   default-router 10.66.66.1
   dns-server 10.10.66.1 8.8.8.8
ip dhcp pool 10
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server 10.10.10.1 8.8.8.8
ip dhcp pool 43
   import all
   network 10.10.43.0 255.255.255.0
   default-router 10.10.43.1
   dns-server 202.67.222.222 8.8.8.8
ip dhcp pool 44
   import all
   network 10.10.44.0 255.255.255.0
   default-router 10.10.44.1
ip ssh version 2
username strato.adm password 7 142406192C107A282B252371
archive
 path flash:
 maximum 5
 write-memory
 time-period 10
interface FastEthernet0/0
 description Outside
 ip address xx.xx.xx.178 255.255.255.240
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet0/1
 description Inside
 no ip address
 no ip route-cache cef
 no ip route-cache
 duplex auto
 speed auto
 no cdp enable
interface FastEthernet0/1.5
 encapsulation dot1Q 5
 ip address 10.10.5.1 255.255.255.0
 ip nat inside
 no ip route-cache
interface FastEthernet0/1.8
 encapsulation dot1Q 8
 ip address 10.10.8.1 255.255.255.0
 no ip route-cache
interface FastEthernet0/1.10
 encapsulation dot1Q 10
 ip address 10.10.10.1 255.255.255.0
 ip nat inside
 no ip route-cache
interface FastEthernet0/1.43
 encapsulation dot1Q 43
 ip address 10.10.43.1 255.255.255.0
 ip nat inside
 no ip route-cache
interface FastEthernet0/1.44
 encapsulation dot1Q 44
 ip address 10.10.44.1 255.255.255.0
 ip nat inside
 no ip route-cache
interface FastEthernet0/1.66
 encapsulation dot1Q 66
 ip address 10.66.66.1 255.255.255.0
 ip nat inside
 no ip route-cache
interface Serial0/0/0
 no ip address
 shutdown
ip route 0.0.0.0 0.0.0.0 xx.xx.xx.177
no ip http server
no ip http secure-server
ip nat pool MGMT-HOME xx.xx.xx.178 xx.xx.xx.178 prefix-length 28
ip nat pool VNC 10.10.10.201 10.10.10.201 netmask 255.255.255.0 type rotary
ip nat pool client-44 xx.xx.xx.179.xx.xx.xx.179 prefix-length 28
ip nat inside source list MGMT-HOME interface FastEthernet0/0 overload
ip nat inside source route-map client-44-rmap pool client-44 overload
ip nat inside source static udp 10.66.66.47 1194 interface FastEthernet0/0 1194
ip nat inside source static tcp 10.10.10.201 3128 interface FastEthernet0/0 3128
ip nat inside source static tcp 10.10.10.201 8006 interface FastEthernet0/0 8006
ip nat inside source static tcp 10.10.10.201 22 interface FastEthernet0/0 22
ip nat inside destination list MGMT-HOME pool VNC
ip access-list extended MGMT-HOME
 deny   ip host 10.10.44.6 any
 permit ip 10.10.10.0 0.0.0.255 any
 permit ip 10.66.66.0 0.0.0.255 any
 permit tcp any any range 5900 5999
ip access-list extended client-44-acl
 permit ip host 10.10.44.6 any
route-map client-44-rmap permit 10
 match ip address client-44-acl
I am able to ping 10.10.44.1 from the virtual machine inside the physical host that is trunked to the switch with vlan tag of 44 that routes to sub interface fa0/1.44     But I can not ping out to google.  If I add
 permit ip 10.10.44.0 0.0.0.255 any
then i can access google fine but i have always thought setting rmaps would work for something like I have and that traffic should hit the first acl, see it denied then go to the next and see it allowed for the other nat pool and allow it out.
Any help is greatly appreciated.
2 Accepted Solutions
ghostinthenet
Level 7
Level 7
Mixing ACL-defined NAT and RM-defined NAT can sometimes produce unpredictable results, as does mixing IP-based NAT and interface-based NAT. Let's standardize on RMs and IP addresses and give this a try:
ip nat inside source route-map MGMT-HOME pool MGMT-HOME overload
ip nat inside source static udp 10.66.66.47 1194 xx.xx.xx.178 1194
ip nat inside source static tcp 10.10.10.201 3128 xx.xx.xx.178 3128
ip nat inside source static tcp 10.10.10.201 8006 xx.xx.xx.178 8006
ip nat inside source static tcp 10.10.10.201 22 xx.xx.xx.178 22
route-map MGMT-HOME permit 10
 match ip address MGMT-HOME
The following configuration entries don't really play into what you appear to be trying to do, so I would take them out for now:
What are you trying to do with those?
Jody Lemoine, Network Architect
CCIE 41436, MTCRE, MTCINE, MTCIPv6E
tishco networks, Virtually Everywhere
(905) 378-1134, jody.lemoine@tishco.ca
For something like this, where I want the networks completely isolated, I usually use a VRF lite configuration.
18 Replies 18
ghostinthenet
Level 7
Level 7
So I am sure some of what I was trying to do was because of my lack of understanding and just trying to stitch things together.
In essence what I want to achieve is I have 2 servers that will provide vps out of my home.  The first ip of my 12 will be for everything in my house that is home related and for a few ports for my business MGMT subnet.  The other IP's will be for different VPS clients that need to have traffic flow in and out of their own subnet to their own NAT ip address but not have access to anything else.
The virtualization software I use has VNC for clients to access their vps via console through my website and since the server controls the vnc to each vps i did a rotary statement for vnc console access to the server internal ip.
Stratocomp wrote 3 minutes ago:
Okay, the configuration example I gave above should cover that easily enough. Let me know if it works for you.
So you're just using destination NAT to be able to forward a huge range of ports inbound then?
So oddly enough after doing that config my computer said I had internet access but i could not ping google dns or access any web page.  below is my config  I did clear ip nat trans to make sure
version 12.4
service timestamps log datetime
service password-encryption
hostname
boot-start-marker
boot-end-marker
aaa new-model
ip cef
ip dhcp pool 66
   import all
ip dhcp pool 10
   import all
ip dhcp pool 43
   import all
ip dhcp pool 44
   import all
ip ssh version 2
archive
 path flash:
 maximum 5
 write-memory
 time-period 10
 description Outside
 ip nat outside
 duplex auto
 speed auto
 description Inside
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no cdp enable
 ip nat inside
 no ip route-cache
 no ip route-cache
 ip nat inside
 no ip route-cache
 ip nat inside
 no ip route-cache
 ip nat inside
 no ip route-cache
 ip nat inside
 no ip route-cache
 no ip address
 shutdown
no ip http server
ip nat pool client-44 xx.xx.xx.179 xx.xx.xx.179 prefix-length 28
logging trap debugging
logging facility local0
logging host 54.228.220.150 transport udp port 10798
control-plane
scheduler allocate 20000 1000
ntp clock-period 17178380
ntp update-calendar
ntp server 72.14.183.239
end
The configuration looks good. Try attempting to ping 8.8.8.8 from the 10.10.10.0/24, 10.66.66.0/24 and 10.10.44.0/24 networks and then do a "show ip nat translations" to see if the translations are being generated properly. Are you able to reach 8.8.8.8 from any of these networks?
So I can not ping 8.8.8.8 from any of the networks but i do see lots of translations under show ip nat trans.
StratoRouter#show ip nat trans
Pro Inside global         Inside local          Outside local         Outside global
tcp xx.xx.xx.178:22       10.10.10.201:22       ---                   ---
tcp xx.xx.xx.178:3128     10.10.10.201:3128     ---                   ---
tcp xx.xx.xx.178:8006     10.10.10.201:8006     ---                   ---
udp xx.xx.xx.178:123      10.10.10.202:123      66.135.44.92:123      66.135.44.92:123
udp xx.xx.xx.178:123      10.10.10.202:123      98.143.24.53:123      98.143.24.53:123
icmp xx.xx.xx.179:1       10.10.44.6:1          8.8.8.8:1             8.8.8.8:1
udp xx.xx.xx.179:123      10.10.44.7:123        198.60.22.240:123     198.60.22.240:123
icmp xx.xx.xx.179:7039    10.10.44.7:7039       8.8.8.8:7039          8.8.8.8:7039
udp xx.xx.xx.178:34215    10.66.66.2:34215      10.10.66.1:53         10.10.66.1:53
udp xx.xx.xx.178:37300    10.66.66.2:37300      10.10.66.1:53         10.10.66.1:53
udp xx.xx.xx.178:38570    10.66.66.2:38570      8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:40858    10.66.66.2:40858      10.10.66.1:53         10.10.66.1:53
udp xx.xx.xx.178:43210    10.66.66.2:43210      10.10.66.1:53         10.10.66.1:53
udp xx.xx.xx.178:46495    10.66.66.2:46495      8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:47632    10.66.66.2:47632      8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:48810    10.66.66.2:48810      8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:51724    10.66.66.2:51724      8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:58686    10.66.66.2:58686      8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:60918    10.66.66.2:60918      10.10.66.1:53         10.10.66.1:53
udp xx.xx.xx.178:52074    10.66.66.18:52074     8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:52074    10.66.66.18:52074     10.10.66.1:53         10.10.66.1:53
udp xx.xx.xx.178:55430    10.66.66.18:55430     8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:55430    10.66.66.18:55430     10.10.66.1:53         10.10.66.1:53
udp xx.xx.xx.178:58194    10.66.66.18:58194     8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:58194    10.66.66.18:58194     10.10.66.1:53         10.10.66.1:53
udp xx.xx.xx.178:63345    10.66.66.18:63345     8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:64540    10.66.66.18:64540     8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:64540    10.66.66.18:64540     10.10.66.1:53         10.10.66.1:53
udp xx.xx.xx.178:54337    10.66.66.20:54337     8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:54337    10.66.66.20:54337     10.10.66.1:53         10.10.66.1:53
icmp xx.xx.xx.178:1       10.66.66.22:1         8.8.8.8:1             8.8.8.8:1
udp xx.xx.xx.178:61853    10.66.66.22:61853     8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:61853    10.66.66.22:61853     10.10.66.1:53         10.10.66.1:53
udp xx.xx.xx.178:64400    10.66.66.22:64400     8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:64400    10.66.66.22:64400     10.10.66.1:53         10.10.66.1:53
tcp xx.xx.xx.178:65161    10.66.66.22:65161     111.221.74.48:40018   111.221.74.48:40018
tcp xx.xx.xx.178:65162    10.66.66.22:65162     111.221.77.162:80     111.221.77.162:80
tcp xx.xx.xx.178:65164    10.66.66.22:65164     64.4.23.143:40001     64.4.23.143:40001
tcp xx.xx.xx.178:65165    10.66.66.22:65165     111.221.74.48:443     111.221.74.48:443
tcp xx.xx.xx.178:65166    10.66.66.22:65166     111.221.77.154:40021  111.221.77.154:40021
tcp xx.xx.xx.178:65167    10.66.66.22:65167     64.4.23.143:443       64.4.23.143:443
tcp xx.xx.xx.178:65169    10.66.66.22:65169     111.221.74.48:80      111.221.74.48:80
tcp xx.xx.xx.178:65170    10.66.66.22:65170     111.221.77.154:443    111.221.77.154:443
tcp xx.xx.xx.178:65171    10.66.66.22:65171     64.4.23.143:80        64.4.23.143:80
tcp xx.xx.xx.178:65173    10.66.66.22:65173     111.221.77.154:80     111.221.77.154:80
tcp xx.xx.xx.178:65174    10.66.66.22:65174     91.190.216.52:12350   91.190.216.52:12350
tcp xx.xx.xx.178:65181    10.66.66.22:65181     91.190.216.52:443     91.190.216.52:443
tcp xx.xx.xx.178:65183    10.66.66.22:65183     91.190.216.52:80      91.190.216.52:80
tcp xx.xx.xx.178:65188    10.66.66.22:65188     157.55.56.140:40033   157.55.56.140:40033
tcp xx.xx.xx.178:65189    10.66.66.22:65189     157.55.130.141:40007  157.55.130.141:40007
tcp xx.xx.xx.178:65191    10.66.66.22:65191     157.55.56.140:443     157.55.56.140:443
tcp xx.xx.xx.178:65192    10.66.66.22:65192     64.4.23.158:40019     64.4.23.158:40019
tcp xx.xx.xx.178:65193    10.66.66.22:65193     157.55.130.141:443    157.55.130.141:443
tcp xx.xx.xx.178:65194    10.66.66.22:65194     157.55.56.140:80      157.55.56.140:80
tcp xx.xx.xx.178:65196    10.66.66.22:65196     64.4.23.158:443       64.4.23.158:443
tcp xx.xx.xx.178:65197    10.66.66.22:65197     213.199.179.146:40021 213.199.179.146:40021
tcp xx.xx.xx.178:65198    10.66.66.22:65198     157.55.130.141:80     157.55.130.141:80
tcp xx.xx.xx.178:65199    10.66.66.22:65199     64.4.23.158:80        64.4.23.158:80
tcp xx.xx.xx.178:65201    10.66.66.22:65201     213.199.179.146:443   213.199.179.146:443
tcp xx.xx.xx.178:65202    10.66.66.22:65202     157.56.52.31:40026    157.56.52.31:40026
tcp xx.xx.xx.178:65204    10.66.66.22:65204     213.199.179.146:80    213.199.179.146:80
tcp xx.xx.xx.178:65205    10.66.66.22:65205     65.55.223.31:40014    65.55.223.31:40014
tcp xx.xx.xx.178:65206    10.66.66.22:65206     157.56.52.31:443      157.56.52.31:443
tcp xx.xx.xx.178:65207    10.66.66.22:65207     157.56.52.21:40005    157.56.52.21:40005
tcp xx.xx.xx.178:65209    10.66.66.22:65209     65.55.223.31:443      65.55.223.31:443
tcp xx.xx.xx.178:65210    10.66.66.22:65210     157.56.52.31:80       157.56.52.31:80
tcp xx.xx.xx.178:65211    10.66.66.22:65211     157.56.52.21:443      157.56.52.21:443
tcp xx.xx.xx.178:65213    10.66.66.22:65213     65.55.223.31:80       65.55.223.31:80
tcp xx.xx.xx.178:65214    10.66.66.22:65214     157.56.52.21:80       157.56.52.21:80
udp xx.xx.xx.178:52733    10.66.66.27:52733     8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:56704    10.66.66.27:56704     8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:63073    10.66.66.27:63073     8.8.8.8:53            8.8.8.8:53
udp xx.xx.xx.178:1194     10.66.66.47:1194      ---                   ---
tcp xx.xx.xx.178:38636    10.66.66.47:38636     209.221.132.10:443    209.221.132.10:443
tcp xx.xx.xx.178:52046    10.66.66.47:52046     209.221.132.9:443     209.221.132.9:443
Okay... it looks like NAT is working. Here we can see that traffic from 10.10.44.0/24 is translating to xx.xx.xx.179 and traffic from 10.66.66.0/24 is translating to xx.xx.xx.178.
Now we just need to figure out why traffic isn't coming back. Are you able to ping 8.8.8.8 from the router?
yes I can ping 8.8.8.8 from the router
Also FYI, here is info from the original guy that helped me try to get this working last year.  He is not around anymore so I can not look to him for help. This is my old config when i had my equipment in a datacenter and it is no longer there.
Below is the simple config for doing what you want it is basicly the same
as the standard nat config. However what you need to be aware of is ALL
traffic that is initiated from the inside will have the have the overload
IP address. Sometimes this is not a problem at all and this will work just
fine.
 description Outside
 ip address 66.182.137.89 255.255.255.248
 ip nat outside
 duplex auto
 speed auto
 description Inside
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip nat inside source list NAT-ACL interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.0.90 443 66.182.137.90 443 extendable
ip nat inside source static tcp 192.168.0.91 443 66.182.137.91 443 extendable
ip access-list extended NAT-ACL
 permit ip 192.168.0.0 0.0.0.255 any
Below is a more coplex config. However it fixes the outbound traffic problem
for the configured machines.
 description Outside
 ip nat outside
 duplex auto
 speed auto
 description Inside
 ip nat inside
 duplex auto
 speed auto
ip nat pool WEB01-NAT-POOL 66.182.137.90 66.182.137.90 prefix-length 29
ip nat pool WEB02-NAT-POOL 66.182.137.91 66.182.137.91 prefix-length 29
ip nat inside source route-map WEB01-NAT-RMAP pool WEB01-NAT-POOL overload
ip nat inside source route-map WEB02-NAT-RMAP pool WEB02-NAT-POOL overload
 deny ip host 192.168.0.90 any
 deny ip host 192.168.0.91 any
ip access-list extended WEB01-NAT-ACL
 permit ip host 192.168.0.90 any
ip access-list extended WEB02-NAT-ACL
 permit ip host 192.168.0.91 any
route-map WEB01-NAT-RMAP permit 10
 match ip address WEB01-NAT-ACL
route-map WEB02-NAT-RMAP permit 10
 match ip address WEB02-NAT-ACL
This looks almost identical to what we have, except that the sample configuration is using ACLs to subdivide the NAT within the same segment rather than doing NAT on separate segments.
What happens when you try "ping 8.8.8.8 source Gi0/1.44" and "ping 8.8.8.8 source Gi0/1.66" from the router?
I'm not seeing anything in the configuration that would account for this. If you can't ping 8.8.8.8 from any of the networks, but there is reachability from the router, there are entries in the NAT table and everything is directly connected, it should be working correctly. Unless there is a typo or mismatch between the various IP references that have been masked with xx.xx.xx.#, everything looks pretty standard here.
StratoRouter#ping 8.8.8.8 source fa0/1.66
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 10.66.66.1
Success rate is 0 percent (0/5)
StratoRouter#ping 8.8.8.8 source fa0/1.44
Packet sent with a source address of 10.10.44.1
StratoRouter#ping 8.8.8.8 source fa0/1.10
Packet sent with a source address of 10.10.10.1
also if i put in
I get internet on my 10.66.66.22 machine
That's very interesting.
and
are functionally identical configurations. If the first one is working and the second one isn't, something is likely wrong with the addressing.
Can you make sure that x.x.x.178 in the "ip nat pool" and x.x.x.178 on the IP address configuration command for interface FastEthernet0/0 are identical and that there isn't a typo?
yea the IP's match up.  Could it be something with the version I have or maybe a route missing or something? Or do I need to assign the route-maps on the sun interfaces?
