NAT Pool not found.
Anyone got an idea why this is not working ?
ip local pool Pool16 80.248.16.16
ip nat inside source route-map RMNoNAT pool Pool16
route-map RMNoNAT, permit, sequence 10
Match clauses:
ip address (access-lists): NoNAT
Set clauses:
Policy routing matches: 0 packets, 0 bytes
20 permit ip host 192.168.97.100 host 10.4.64.201
30 permit ip host 192.168.97.254 host 10.4.64.201 (30 matches)
*Oct 8 19:03:15: NAT: alloc -- pool Pool16 not found
*Oct 8 19:03:15: NAT: translation failed (E), dropping packet s=192.168.97.254 d=10.4.64.201
Pool Begin End Free In use
Pool16 80.248.16.16 80.248.16.16 1 0
c2800nm-advsecurityk9-mz.124-3a.bin
You are missing the NAT pool. Can you configure this command and test.
ip nat pool Pool16 80.248.16.16 80.248.16.16 netmask 255.255.255.252
Sundar
