NAT problem , the CPU becomes FULL
mendrika13
We have got some problem in our router (a 1841, IOS Version 12.4(15)T12),
I activated the command "debug ip packet" (to observ nat translation) then the cpu became full (100%) and I wasn't able to reach the management IP of it.
After restarting the router, I can reach it BUT the cpu still in very high average 80-100% and we have loss some packets.
What should we do to decrease the CPU utilisation?
How can I be sure that the debug ip packet is off ? (I tried the command "show debugging {condition} {all}" but no result)
Thank you
Philip D'Ath
If you rebooted the router then all debugs are cleared.  You can see debugs with:
show debug
If you want to see NAT translations you can:
show ip nat translations
Yes, "debug ip packet" puts the router under considerable load and should not be used except for very lightly loaded routers at non-production times.
