NAT Question
sometechguy
Level 2
Level 2
I have two private networks that touch at a NAT router:
192.168.16.0/24
10.1.0.0/24
I have a workstation with an IP address of 192.168.16.10 that needs to access the server resources on IP address 10.1.0.23. For security reasons, we want to use NAT to perform this (with ACLs).
Without having to change any route entries on the Windows workstation (basically point the application to a NAT 192.168.16.x), what would the configuration look like on the Cisco router? (as far as "ip nat ..." commands are concerned).
Marwan ALshawi
i will consider that u want NAT the communications between the workstation and the server only as mentioned above
lets say u will give the server with this static nat na ip address of 192.168.16.100
ip nat inside source static 10.1.0.23 192.168.16.100
interface fa0/0
description the interface connnected to the servver side
ip nat inside
interface fa0/1
description interface connected to clients
ip nat outside
and now from the client side u can use the 192.168.16.100 as the server address even u cam make ACLs to filter traffic to this IP
good luck
Rate if helpful
