NAT to conceal outside global IP
spacemky
Hey Pros,
I have 2 networks with a router between them.
Network A --router-- Network B
Network A= inside
Network B= outside
I want it so that when Network B sends traffic destined through the router, Network A does not see the true IP of the host who actually sent the traffic, but sees an IP address from the router. Is this possible? I can do this easily with Linux using ip masquerade (ipmasq). Thanks pros!
John Blakley
Here's an example:
Network B
int fa0/0
desc WAN
ip nat outside
int fa0/1
desc LAN
ip address 10.50.50.1 255.255.255.0
ip nat inside
ip nat inside source list 1 interface fa0/0 overload
access-list 1 permit 10.50.50.0
Anyone coming from 10.50.50.0/24 lan side will look like they're coming from 192.168.1.1.
HTH,
John
HTH, John *** Please rate all useful posts ***
*Bingo!* worked perfectly. I guess the idea was swapping the concept of what was inside and what was outside. Many thanks j.blakley.
I'm trying to take this one step further. From you example, how would I make a static NAT entry where people connecting from f0/1 could be statically NATted to a host on f0/0?
For example, I want users to connect to a new IP address, 10.50.50.2 TCP port 80. Traffic gets NATted and sent to 192.168.1.2 port 8080.
I've tried:
ip nat inside source static tcp 192.168.1.2 8080 10.50.50.2 80
But this doesn't seem to work. Thanks!
