Native trunk vlan question
Davidc2478
Hello all, I researched this question but didn't find a simple explanation. Adding a wireless access point.
Example:
int gi1/1/1
switchport mode trunk
switchport trunk native vlan 100
switchport trunk allowed vlan 100,200,300
The AP speaks over vlan 100 untagged, and has ssid's on vlan 200 and vlan 300 tagged
Why is it with this configuration I can ping the AP, but if I were to remove vlan 100 from allowed, I cannot? I thought by having vlan 100 as native trunk it would grant "access". No?
I just lab tested this, indeed you need to allow the native Vlan, otherwise no communication will occur. I think that is because the native Vlan (100 in your case) is actually carrying user traffic, (and you probably have switchports in access mode assigned to Vlan 100 ?)...
Hello
If your network is using vlan 100 to carry untagged traffic and then it is pruned from the trunk then connectivity to devices in vlan 100 won’t work, however if that vlan 100 is only being used to reference an unused untagged vlan then it isn’t required to be allowed over the trunk, just on the trunk between the two devices that directly connected.specifed are native
Kind Regards
Paul
Davidc2478
I appreciate the info. I come from a Extreme Networks world, so I'm trying to get used to the extra details required when configuring Cisco switches.
