Native vlan 802.1q and ISL ?
philipbarker
I have a 802.1q trunk and an ISL trunk conigured between two switches.
When I 'sh int trunk' the output shows the native vlan as 1 for both 802.1q AND ISL ?
Does 'native vlan' have any meaning within ISL ? I don't think it does but just need to confirm.
I think I have verified this in the following way:
I changed the native vlan on one end of each trunk (the 802.1q and ISL) respectfully and CDP only complains about NATIVE_VLAN_MISMATCH for the 802.1q trunk.
Phil.
Jon Marshall
Hi Phil
Yes you are correct. ISL tags all frames and does not have a concept of a native vlan as such where the native vlan sends packets that do not have a vlan tag.
The native vlan in 802.1q was designed to allow compatability with older switches that did not support tagged frames.
Jon
Jon Marshall
Hi Phil
Jon
minor correction...ISL doesn't tag, it encapsulates. dot1q tags.
http://www.cisco.com/warp/public/473/741_4.html
that was mainly for the benefit of the OP..
