Native vlan issues
rhamietron
Community Member
Please I dont seems to see what the issue is here.
Find below the output from the sh run
SoneraCloud#sh interfaces gigabitEthernet 0/1 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: 301 (VLAN0301)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
--More--
01:49:58: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on GigabitEthernet0/1 (301), with Valimo FastEthernet0        .
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Valimo#sh int fa0/1 switchport
Switchport: Enabled
Administrative mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Disabled
Access Mode VLAN: 0 ((Inactive))
Trunking Native Mode VLAN: 451 (VLAN0451)
Trunking VLANs Enabled: 1,197,451,1002-1005
Trunking VLANs Active: 1,451
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Self Loopback: No
Look forward to your help.
Raheem
Kyle McKay
Level 7
Level 7
When comparing the two outputs it is clear that the native VLAN is different on each of the ports.
On Valimo it is 451 and on SoneraCloud it is 1 (default).
CDP identifies this through its message exchange and provides the log message that you have pasted.
You will need to correct this configuration on either side in order to make them consistent otherwise you will continually see these log messages.
Here is the command to change the native vlan for your reference:
switchport trunk native vlan x     (where x i the VLAN you choose)
on Sonera Cloud is :
Mind the fact that you have static access on one side and trunking on the other side.
Yes it is.
Thanks for pointing that outabout the static access.
I have got it fixed. What I did was to have simlar configuration as that of the fa0/1 interface on a gi0/2 interface.
Immideiately I did this, it all went ok and the QinQ tunnelling config allows traffic from the non tagged access port.
But could you tell me the implication of the static access for future situation.
I have used switchport native vlan x command earlier before posting.
But I guess i chose a wrong vlan ID
