Native VLAN mismatch between VSS 6509 and 3560
varunk2k3
I am getting logs on Access switch 3560 CDP native VLAN mismatch, i've validated the configuration on both switch but still we are getting the error.
bly-VSS-core01#sh run int  po 40
Building configuration...
Current configuration : 330 bytes
interface Port-channel40
description Link to bly-09-01s2
switchport
switchport trunk native vlan 230
switchport trunk allowed vlan 1,2,7,13,65,105,136,137,152,223,230,253,502,548
switchport trunk allowed vlan add 550,551,873
switchport mode trunk
no mls qos channel-consistency
end
bly-VSS-core01#sh interfaces trunk module 3
Port                Mode         Encapsulation  Status        Native vlan
Gi1/3/1             on           802.1q         trunking      950
Gi1/3/2             on           802.1q         trunk-inbndl  1
                                      (Po49)
Gi1/3/3             on           802.1q         trunk-inbndl  1
                                      (Po50)
Gi1/3/13            on           802.1q         trunk-inbndl  230
                                      (Po40)
Gi1/3/14            on           802.1q         trunk-inbndl  230
bly-VSS-core01#sh cdp neighbors  Gi1/3/13 detail
Device ID: bly-09-01s2
Entry address(es):
  IP address: 191.255.1.173
Platform: cisco WS-C3560G-48TS,  Capabilities: Switch IGMP
Interface: GigabitEthernet1/3/13,  Port ID (outgoing port): GigabitEthernet0/49
Holdtime : 167 sec
Version :
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 18:15 by nachen
advertisement version: 2
Protocol Hello:  OUI=0x00000C, Protocol ID=0x0112; payload len=27, value=00000000FFFFFFFF0102250A00000000000004FE7F752680FF0000
VTP Management Domain: '****************'
Native VLAN: 230 (Mismatch)
Duplex: full
Management address(es):
bly-VSS-core01#
bly-09-01s2# sh run int po 10
Current configuration : 289 bytes
interface Port-channel10
description Link to bly-VSS-core01
end
Gi0/45      auto         negotiate      other         1
Gi0/46      auto         negotiate      other         1
Gi0/47      auto         negotiate      other         1
Gi0/48      auto         negotiate      other         1
Gi0/49      on           802.1q         trunk-inbndl  230
                                      (Po10)
Gi0/50      on           802.1q         trunk-inbndl  230
                                      (Po10)
bly-09-01s2#sh cdp neighbors  d
Device ID: bly-VSS-core01
Entry address(es):
  IP address: 191.255.1.10
Platform: cisco WS-C6509-E,  Capabilities: Router Switch IGMP
Interface: GigabitEthernet0/50,  Port ID (outgoing port): GigabitEthernet2/3/13
Holdtime : 142 sec
Version :
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXH5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 16-Apr-09 19:28 by prod_rel_team
VTP Management Domain: '**************'
Native VLAN: 1 (Mismatch)
Duplex: full
Sep 23 02:05:55.653: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on GigabitEthernet0/49 (230), with bly-VSS-core01 GigabitEthernet1/3/13 (1).
Sep 23 02:06:11.206: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on GigabitEthernet0/50 (230), with bly-VSS-core01 GigabitEthernet2/3/13 (1).
Rasika Nayanajith
It looks like 6509 switch still believe vlan 1 is the native vlan. Please check "show interfaces g1/3/13 switchport" & "show interfaces g2/3/13 switchport" confirms trunking native vlan is 230.
Post that output if you could
Rasika
**** Please rate all useful responses ****
I think if i disable the switchport on 6509 it will resolve the problem.
bly-VSS-core01#show interfaces g2/3/13 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk (member of bundle Po40)
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 230 (SIDES-JumpStart)
Administrative Native VLAN tagging: enabled
Operational Native VLAN tagging: disabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Operational private-vlan: none
Trunking VLANs Enabled: 1,2,7,13,65,105,136,137,152,223,230,253,502,548,550,
     551,873
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
bly-VSS-core01#
Hi Varun,
Are you seeing this logs after any recent configuration change? What IOS version you are running on both devices? Could you please try removing the interfaces from the bundle and try reapplying the channel-group command back on the interface and verify if you see any improvement?
Najaf
