Native VLAN mismatch detected on interface PO4
cre8toruk
Hi All,
got this annoying CDP message which I don't seem to be able to shake off.
350XG connected to a SF300 via PO4 (port channel is PO4 on both switches to be helpful :-))
On SW2 (SF300) the ports gi51 & gi52 make up the port channel.... config below.
interface gigabitethernet51
 description CORE-SW-UPLINK-01
 spanning-tree link-type point-to-point
 channel-group 4 mode auto
 no macro auto smartport
interface gigabitethernet52
 description CORE-SW-UPLINK-02
interface Port-channel4
 description CORE-SW2
 switchport trunk allowed vlan add 10,101-103,190,200,254,400,2122
 switchport trunk allowed vlan add 2126
 macro description "switch   "
 !next command is internal.
 macro auto smartport dynamic_type unknown
on the 350XG PO4 is made up of te1/0/2 and te2/0/2 config below
interface TenGigabitEthernet1/0/2
 description CORE-SW2-1
 switchport mode trunk
 switchport trunk allowed vlan 10,101-103,190,200,254,400,2122,2126
 macro auto smartport dynamic_type switch
interface TenGigabitEthernet2/0/2
 description CORE-SW2-2
interface Port-Channel4
If I check all ports for native vlan they say Native VLAN is VLAN 1 (on both switches).
SW1:
show int switchport po4
S-VLAN Ethernet Type:  0x8100 (802.1q)
VLAN Mapping Tunnel L2 protocols Global CoS: 5
Switchport: enable
Administrative Mode: trunk
Operational Mode: up
Access Mode VLAN: 1
Access Multicast TV VLAN: none
Trunking Native Mode VLAN: 1 (Inactive)
Trunking VLANs: 10,101-103,190,200,254,400,2122,2126
General PVID: 1
General VLANs: none
General Egress Tagged VLANs: none
General Forbidden VLANs: none
General Ingress Filtering: enabled
General Acceptable Frame Type: all
General GVRP status: disabled
Customer Mode VLAN: none
Customer Multicast TV VLANs: none
Private-vlan promiscuous-association primary VLAN: none
Private-vlan promiscuous-association Secondary VLANs: none
Private-vlan host-association primary VLAN: none
Private-vlan host-association Secondary VLAN: none
SW2:
Show int switch po4
Port : Po4
Port Mode: Trunk
Gvrp Status: disabled
Ingress Filtering: true
Acceptable Frame Type: admitAll
Ingress UnTagged VLAN ( NATIVE ): 1
Port is member in:
Vlan               Name               Egress rule     Added by
 1                  1                  Untagged          V
 10              SERVERS                Tagged           S
101             MEL-MOBILE              Tagged           S
102             MEL-PUBLIC              Tagged           S
103            MEL-CONTROLS             Tagged           S
190            MEL-WIRELESS             Tagged           S
200             ENDPOINTS               Tagged           S
254           OTHER-DEVICES             Tagged           S
400          BURKINA-CONTROLS           Tagged           S
2122            NIMROD-DSL              Tagged           S
Any ideas how I can correct the CDP error ? Also on SW should te1/0/2 & te2/0/2 be configured like that if they're part of a port channel ? SW2 wouldn't let the ports have any configuration prior to being added to the port channel.
Grateful for all assistance as ever.
Paul.
5 Replies 5
it could be that the first port channel doesn't like to be the allowed vlans being configured on two separate lines, while the other side has them on a single line. Try and configure them both with one single line.
--> switchport trunk allowed vlan add 10,101-103,190,200,254,400,2122. 2126
Jaderson Pessoa
@cre8toruk Hello,
Try it:
switchport trunk allowed vlan add 2126 channel-group 4 mode auto no macro auto smartport ! interface gigabitethernet52 description CORE-SW-UPLINK-02
switchport trunk allowed vlan add 2126 channel-group 4 mode auto no macro auto smartport interface Port-channel4 description CORE-SW2 spanning-tree link-type point-to-point switchport trunk allowed vlan add 10,101-103,190,200,254,400,2122 switchport trunk allowed vlan add 2126 macro description "switch " !next command is internal. macro auto smartport dynamic_type unknown
Jaderson Pessoa
*** Rate All Helpful Responses ***
Right after a lot of Googling etc.. I tried the above btw... I resolved to simply disable the message... thanks to all for your assistance.
well.. disabling the message doesn't resolve it. Good lucky :)
Jaderson Pessoa
No I know but in the grand scheme, if the error is a bug in the software I figured I shouldn't waste more time on it :-)… Thanks.
