native vlan on switch port
suthomas1
Level 6
Level 6
We are configuring a router and switch for a location with following configuration outline.
1. Routers gi0/0/0 connects to fa0/48 on switch
2. Router will be as dot1q with multiple segments tied from gi0/0/0
3. Switch fa0/48 will be a trunk allowing all vlans , switch itself will have about 7 layer2 vlans
4. Management for both router and switch will be on vlan 100(192.168.100.0/28)
router - 192.168.100.11 & switch - 192.168.100.12
interface GigabitEthernet0/0/1.100 (on router)
description device management
encapsulation dot1Q 100
ip address 192.168.100.11 255.255.255.240
interface fa0/48 (on switch)
switchport mode trunk
switchport trunk native vlan 8
int vlan 100 (on switch )
ip address 192.168.100.12 255.255.255.240
5. The router will do all routing upstream and the switch will only have layer 2 functionality
In this case, will the fa0/48 config on switch work well from a native vlan perspective?
Do we need to specify explicity vlan 8 as native on switch port fa0/48? What happens if we
do not specify (which will then default native to 1) ?
Will this affect connectivity in any aspect for the rest of vlans on that location.
please help with inputs.
Hello
By default the native vlan will be on the physical interface of the router, Now as the router is performing the inter-vlan routing and you have also specified native vlan 8 on the switch trunk then on the router you could also make its related sub-interface native with/without ip addressing.
interface GigabitEthernet0/0/1.8 (on router)
encapsulation dot1Q 8 native
no ip address
No you don't have to specify any native vlan and the default will be vlan 1 on the physical interface of the router and on the trunk of the switch and all should work accordingly
Kind Regards
Paul
Hello
no ip address
Kind Regards
Paul
The original poster has not told us much about vlan 8. We are told that the switch is performing layer 2 forwarding with no layer 3 processing other than the IP for the management interface. If the intent is that there will be hosts connected in vlan 8 that need to access resources outside of vlan 8 then the router sub interface for vlan 8 needs to have an IP address. If vlan 8 does not have hosts that need to be routed then the suggestion of the router sub interface for vlan 8 with no ip address would be fine.
Rick
Rick
