Native Vlan1 over Trunk
David Kondicz
Hi all,
if i have this config:
switchport mode trunk
trunk aloved vlan 50
will travel over this trunk untaged packets? For eg the vlan 1 is by default native vlan without tag.
If i have created a bog ring with catalyst 3560x switches with no spanning tree on vlan 1 can be the case of this config a loop ???
I am using upper config on interfaces that are connected the switches  together in ring.
Other interfaces on switch have this config:
int range 0/1-4
switchport mode acc
switchport acc vlan1
int range 0/5-24
switchport mode acc
switchport acc vlan50
I am using vlan1 just for local switching without connection to internet!
Thank you guys for fast answers.
I am asking just becouse i have this king of messages in logs:
%CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on GigabitEthernet1/0/27 (1), with SW3560x_BR8874 GigabitEthernet1/0/19 (50).
GI 1/0/27 and GI 1/0/19 have this config:
BR
Dave
Jan Hrnko
Level 4
Level 4
Hi David,
the problem is that on port GigabitEthernet1/0/27 you have VLAN 1 configured as native vlan and on port GigabitEthernet1/0/19 the native VLAN is 50. You MUST have both sides of a trunk configured with SAME native VLAN even if you block this VLAN. I believe that it is because of CDP that runs even when no VLANs are allowed on a trunk - it is simply VLAN independent. (STP is not, but if you have blocked vlan 1 so that no traffic will pass through (despite the disabled spanning tree in vlan 1), it should be ok = no switching loops).
So the solution is to either have VLAN1 or VLAN50 as native on both ends of the trunk (po Gi1/027 on one switch and Gi1/0/19 on another).
Best regards,
Jan
5 Replies 5
Jan Hrnko
Level 4
Level 4
Hi David,
Best regards,
Jan
Thank you for fast answer!
I dont know why it hapends, that sometimes i have 5min -300sec outages on this vlan.
I thought that this was the config problem.
Next thing is that i havent set any native vlan on switch. By default native vlan is vlan1, but i added some ports to vlan 50 for internet connection. I just made it with : switchport acces vlan 50, no native vlan 50
BR
dave
Hi David,
no need to thank me , I am glad if I can help.
Aaah I see, but can you please post the output of following command on SW3560x_BR8874?
show interfaces GigabitEthernet 1/0/19 switchport
Because the cdp error message is quite clear, I'm just curious...maybe someone configured it before? The addition of the other ports doesn't matter really in this case... it should be related to port 1/0/19 only.
You have outage in vlan1? How often? It sure is strange, 5min sounds like ARP table or MAC table timeout...maybe we can figure it out somehow. Have you noticed anything strange regarding the outage? Have you tried some debug commands or look into MAC address table?
Best regards,
Jan
Hi Jan,
here is the required info from interface:
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: 50
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: true
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Hi David,
everything seems to be in order and it is quite strange. I don't know what can cause such CDP messages to be populated...but still thinking about it. I will let you know if something comes to my mind, in the meantime I would like to test this in the lab, would you mind attaching configs in .txt files somewhere here? Maybe then I could find the error causing this messages appearing.
Just one more thing... if you are in a production network ( not lab environment ) I highly suggest you to NOT turn off the STP in any VLAN - just in case. It is not that much of a burden and you will sleep much better knowing there is a protocol which can deal with loops if some occur (even by accident / misconfiguration).
Best regards,
Jan
