Natting on nexus n9k-c9348gc-fxp is full
rabmou
Hi all,
i have the below running config internet is working and dropping on vlan due to the vlan translation is reaching the maximum after clearing the translation internet is back. kindly any help on what config should be applied to resolve this.
ip domain-lookup
ip access-list NAT_ACL
10 permit ip 10.0.1.0 0.0.0.255 any
20 permit ip 10.0.2.0 0.0.0.255 any
class-map type qos match-all copp-system-p-class-nat-flow
copp profile strict
snmp-server user admin network-admin auth md5 0xc340d402f79be327ee57064573451d04 priv 0xc340d402f79be327ee57064573451d04 localizedkey
rmon event 1 description FATAL(1) owner PMON@FATAL
rmon event 2 description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 description ERROR(3) owner PMON@ERROR
rmon event 4 description WARNING(4) owner PMON@WARNING
rmon event 5 description INFORMATION(5) owner PMON@INFO
ip route 0.0.0.0/0 192.168.1.1
ip route 0.0.0.0/0 192.168.10.1
vlan 1,10,20
ip nat pool 1 10.0.3.1 10.0.3.10 netmask 255.255.255.0
ip nat pool internet 10.0.30.1 10.0.30.30 prefix-length 24
ip nat translation timeout 60
ip nat inside source list NAT_ACL interface Ethernet1/48 overload
vrf context management
hardware access-list tcam region ing-racl 256
hardware access-list tcam region ing-l3-vlan-qos 256
hardware access-list tcam region nat 2048
hardware access-list tcam region ing-l3-span-filter 512
interface Vlan1
interface Vlan10
no shutdown
ip address 10.0.1.1/24
ip nat inside
interface Vlan20
no shutdown
ip address 10.0.2.1/24
interface Ethernet1/1
switchport
switchport access vlan 10
no shutdown
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
interface Ethernet1/26
interface Ethernet1/27
interface Ethernet1/28
interface Ethernet1/29
interface Ethernet1/30
interface Ethernet1/31
interface Ethernet1/32
interface Ethernet1/33
interface Ethernet1/34
interface Ethernet1/35
interface Ethernet1/36
interface Ethernet1/37
interface Ethernet1/38
interface Ethernet1/39
interface Ethernet1/40
interface Ethernet1/41
interface Ethernet1/42
interface Ethernet1/43
interface Ethernet1/44
interface Ethernet1/45
interface Ethernet1/46
interface Ethernet1/47
ip address 192.168.2.98/24
no shutdown
ip address 192.168.10.20/24
ip nat outside
no shutdown
interface Ethernet1/49
interface Ethernet1/50
interface Ethernet1/51
interface Ethernet1/52
interface Ethernet1/53
interface Ethernet1/54
interface mgmt0
vrf member management
line console
line vty
boot nxos bootflash:/nxos.9.3.2.bin
Reza Sharifi
Try changing the timeout value to a higher number:
ip nat translation timeout 15000
 and test again.
this was tested and not working. it is causing the timeout to be for longer time.
Thank you
