Natting on noswitch port interfaces?
Patrick.Beaven
Is is possible to nat on an interface in non-switchport mode? I would need to be able to nat a few addresses on each interface. Is this possible on a 450X and or 650x chassis switch?
Jon Marshall
Patrick
When you say a "non switchport mode" presumably you mean a routed port ie.
int gi1/0
no switchport
ip address x.x.x.x x.x.x.x
If so then yes as far as i know you can do this on a 6500 as it is just like any other L3 port.
On a 4500 no you can't because the 4500 doesn't support NAT.
Jon
Thanks for the info.
