07-27-2009 08:46 AM - edited 03-06-2019 06:57 AM
I have ver 12.1.(13)EW on this switch. We have a Fluke OptiView to help in network troubleshooting. But in order to pull a history from the device I have to turn on RMON.. In the 4006 under config t... You have two choice with RMON alarm or RMON event I don't understand how I use these so I can see the usage history from our Fluke Optiview...
07-27-2009 09:01 AM
Hello David,
you can use the following for RMON
or
with RMON the devices collects SNMP MIB variables over time on itself and can send messages (alarms) when a specified condition (event) happens this is different from SNMP polling where an agent performs gets every x minutes.
Hope to help
Giuseppe
07-27-2009 09:08 AM
Router(config-if)# rmon collection history {controlEntry integer} [owner ownername] [buckets bucket-number] [interval seconds]
Enables an RMON history group of statistics on an interface.
rmon collection history is what I believe I have and naturally I guess either my IOS doesn't support it or I need another Sup engine.
07-27-2009 09:12 AM
4000 IOS 12.1 only supports mini-RMON
What sup model do you have?
07-27-2009 09:15 AM
according to cisco view...
WS-X4515 Supervisor Engine IV
07-27-2009 09:17 AM
Hello David,
the link I've provided is not specific of your platform.
of course what you see is what you can get on the device.
Hope to help
Giuseppe
07-27-2009 09:22 AM
Supervisor Engine IV can run 12.2 codes so you can consider moving to a newer IOS but consult with Fluke to know what kind of config you need on the switch for your particular traffic/event monitoring needs
