NBAR2 Protocol Pack c
keiththomas
Community Member
I am trying to load the latest protocol pack on a C1921 (ISR  G2)
I have the required IOS (15.2(4)M1)
I have the required license (Data)
I have downloaded the latest protocol pack to my tftp server (also put a copy on the router's flash)
The CLI command to specify the protocol pack does not provide syntax as described in the documentation.
What I get is
C1921-202TL(config)#ip nbar protocol-pack ?
  ftp:    Load protocol pack from ftp:
  http:   Load protocol pack from http:
  https:  Load protocol pack from https:
  pram:   Load protocol pack from pram:
  rcp:    Load protocol pack from rcp:
  scp:    Load protocol pack from scp:
  tftp:   Load protocol pack from tftp:
and when I try to specify, tftp, it provides no context for tftp arguments and will not accept no arguments...
C1921-202TL(config)#ip nbar protocol-pack tftp: ?
  force  Force
  <cr>
% NBAR Error: Unable to open file
It never reaches a context to complain about the file itself, only that the file is not properly specified.
I'm probably missing something obvious. Any helpful ideas?
Thanks.
Ricky.Rorex
Community Member
Same problem here. I know they are relatively new but surely someone here has experience with nbar2 protocol packs on ISR G2s.
