NEC ip phone with cisco 3650 POE
khaled alodat
Can some one help me please ?
I have NEC ip phones that i need to move them from HP to cisco switches.
I have created two vlans , one for the data and one for the voice . the problem is when i connect the phone to the port, it get an ip from the data vlan .
I've tried many things but i could not get the problem solved, i have tried the following
1- interface GigabitEthernet0/12
    switchport voice vlan 2
    spanning-tree portfast
2- interface GigabitEthernet0/12
    switchport mode trunk
 Change from CDL to LLDP
Nothing seems to be work
with everything i tried, the phone keep getting ip from the data vlan not the voice.
Both DHCP scopes are configured on the switch (for testing)
8 Replies 8
kikkyo2013
Hi Khaled,
I have a same problem now. if you solved this problem, would you tell me how you solved?
I use access vlan istedad of voice vlan as workaround now.
Mitsuo
Hi Mitsou,
If the phones have been registered in a previous setup it will not pick a new ip , you have to delete the configs on the phones flash and reconnect them again to the switch.
I hope this help.
Hi Khaled,
Thank you for your kindly reply.
at that time, did you use access VLAN or voice VLAN?
Mitsuo
Voice vlan and LLDP enable .
Hope this help
would you tell me how did you use voice VLAN?
in my case, I configured PoE switch below, but voice VLAN didnn't work...
interface GigabitEthernet0/2
switchport voice vlan 518
but IP phone works when I set "access vlan 518"...
I couldn't understand because I couldn't set voice vlan in IP Phone...
on the global config mode
sw1(config)# lldp run
NEC phone don't understand cdp so the switch will not found a phone unless you enable the lldp .
after that you can check if the phone has been detected by issuing
# show lldp neighbour
now it it should work with voice vlan command
I will try it! thank you so much
Mitsuo
Gracias por la ayuda, me sirvió bastante.!
