Need command to increase output queue on GigaEthernet Port
rlortiz
I have a site with GigaEthernet ports on a Cat 4006. I need to increase the output queue buffer from its default of 40. How can I do this?
sh int g4/4
GigabitEthernet4/4 is up, line protocol is up (connected)
Queueing strategy: fifo
Output queue: 0/40 (size/max)
I am running IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I5K91S-M), Version 12.2(20)EW, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
interface GigabitEthernet4/4
description PRDRDAAPP01
switchport trunk allowed vlan 22,28
switchport mode trunk
logging event link-status
speed 1000
no snmp trap link-status
spanning-tree portfast
pkhatri
Level 11
Level 11
Use the command 'hold-queue 100 out' under the interface to change it to 100.
Paresh.
PS. Pls do remember to rate posts
Paresh,
It looks like hold-queue is not a valid command under the interf g4/4.
(config)#int g4/4
(config-if)#?
Interface configuration commands:
access-group Access group configuration
arp Set arp type (arpa, probe, snap) or timeout
auto Configure Automation
backup Modify backup parameters
bandwidth Set bandwidth informational parameter
bgp-policy Apply policy propogated by bgp community string
carrier-delay Specify delay for interface transitions
cdp CDP interface subcommands
channel-group Etherchannel/port bundling configuration
channel-protocol Select the channel protocol (LACP, PAgP)
clns CLNS interface subcommands
crypto Encryption/Decryption commands
dampening Enable event dampening
default Set a command to its defaults
delay Specify interface throughput delay
description Interface specific description
dot1x Interface Config Commands for 802.1x
duplex Configure duplex operation.
exit Exit from interface configuration mode
flow-sampler Attach flow sampler to the interface
flowcontrol Configure flow operation.
help Description of the interactive help system
ip Interface Internet Protocol config commands
isis IS-IS commands
iso-igrp ISO-IGRP interface subcommands
keepalive Enable keepalive
l2protocol-tunnel Tunnel Layer2 protocols
lacp LACP interface subcommands
load-interval Specify interval for load calculation for an interface
logging Configure logging for interface
loopback Configure internal loopback on an interface
mac MAC interface commands
macro Command macro
max-reserved-bandwidth Maximum Reservable Bandwidth on an Interface
mtu Set the interface Maximum Transmission Unit (MTU)
no Negate a command or set its defaults
pagp PAgP interface subcommands
qos QoS configuration
rmon Configure Remote Monitoring on an interface
service-policy Configure QoS Service Policy
shutdown Shutdown the selected interface
snmp Modify SNMP interface parameters
spanning-tree Spanning Tree Subsystem
speed Configure speed operation.
storm-control storm configuration
switchport Set switching mode characteristics
timeout Define timeout values for this interface
transmit-interface Assign a transmit interface to a receive-only interface
tx-queue Configure interface transmit queue
udld Configure UDLD enabled or disabled and ignore global UDLD setting
Have you tried using the tx-queue command ?
Paresh
I did some research on tx-queue and it doesn't look like this affects the output queue. However, I will see if my remote site can try it.
