Changing a VLAN STP priority
h.bradley
Community Member
We have three 6509's basically connected in a chain. The first two 6509's share the responsibility of being the root bridges for all the VLAN's. The first two also run HSRP. Switch 1 is primary root for odd numbered VLAN's and secondary for even's. Vice versa for Switch 2.
My problem is that several VLAN's were added recently, but were not given any sort of priority. Consequently, the third switch has become the root for these. If I add the new VLAN's to the proper STP roots, am I going to cause an outage on all VLAN's while the spanning tree is recomputed or just the new ones?
The commands I use are:
spanning-tree vlan 2,4,6 priority 8192
spanning-tree vlan 3,5,7 priority 16384
pkhatri
Level 11
Level 11
Given that you are using PVST(+) only the affected VLANs will experience an outage.
Paresh
pkhatri
Level 11
Level 11
Paresh
Thank you for the reply Paresh. You've set my mind at ease.
Hugh
