04-11-2025 05:11 AM
Hello
I have a Cisco Catalyst 2960-X Series switch that is not booting properly. It continuously restarts and does not complete the boot process. I need an experienced network technician or Cisco expert to diagnose and fix this issue.
Requirements:
Experience with Cisco Catalyst switches, particularly the 2960-X Series
Strong troubleshooting skills for boot and firmware issues
Ability to guide me remotely or provide step-by-step instructions
Knowledge of ROMMON mode, IOS recovery, and switch diagnostics
I was try IOS images via TFTP, ROMMON mode but not work ، can you fix
Give me this error
POST: PortASIC Port Loopback Tests: Begin
POST: Failed Port PhyLoopback Packet Test asic_index 0 port_hardware_index 4
POST: PortASIC Port Loopback Tests: End, Status Failed
Error: ASIC/PHY POST failed. Cannot continue.
If you have experience resolving similar issues, please reach out with your approach and estimated time to fix.
Looking forward to working with you!
04-11-2025 05:35 AM
Looks like hardware failure. You need to open a TAC case and try to issue a Return Material Authorization (RMA) to replace the switch.
04-11-2025 09:22 AM
I don't know how to do it. Can you explain please
04-11-2025 11:10 AM
Please check this link and the requirements.
04-11-2025 12:48 PM
I tried to contact with him but to me they need the Cisco ID number. I don't have this one. I buy it. This is from shop so he told me I can't help you. If you don't have Cisco ID. Can you please help me for this issues I don't know
04-11-2025 04:46 PM
Did someone attempted to upgrade the IOS of the switch?
