Need fix for CVE-2004-2761
rahul kale
Tenable says Switches and WLCs are vulnerable for CVE-2004-2761.SSL Certificate Signed Using Weak Hashing Algorithm.
Please help with fix
balaji.bandi
what switch model and WLC example : what code they running ?
the CVE might be old
MD5 in the signature algorithm of an X.509 certificate  -
Look at the bug : (see some workaround suggested way back 2009)
https://bst.cisco.com/bugsearch/bug/CSCvn60539
also look at below thread :
https://community.cisco.com/t5/network-security/https-scan-reveals/td-p/1628713
BB
Leo Laohoo
@rahul kale wrote:
CVE-2004-2761
I have purposely highlighted the CVE number to demonstrate that this CVE was discovered back in 2004.
If there are equipment(s) that were purchased back then, there is no other fix other than a physical replacement.
I have same problem with Switch C9300-24UX-E is vulnerable for CVE-2004-2761.SSL Certificate Signed Using Weak Hashing Algorithm.
Please Suggest
