08-20-2006 10:54 PM - edited 03-05-2019 12:01 PM
Please someone help me. What can I do to a router giving me output in such a language?
gj?) ??<??s??f???>?
Solved! Go to Solution.
08-21-2006 01:20 AM
try other speeds of console : 2400, 19200...
08-21-2006 12:28 AM
Which series of router this is ?
Try the following
* remove all modules, then boot the router if works then
1) of the router & put a single module in router.Then power on.
2) if works with one module then switch of & put second one.
* if Router does not boot while no modules in router then copy new copy IOS.
* Please check whether all modules are on theire place.
08-21-2006 01:18 AM
check the console rate
is it 9600 ?
08-21-2006 01:20 AM
08-21-2006 03:48 AM
pls send the toatal output from start line.
